Would like to get into the Mule project
Hey again all,
Another thought's been floating around in my head for a while now. I'd like to break into the Mule project, seems like a great idea as described on Spyderco's website and from the praise I've seen in all the forums.
My only problem (and I saw this mentioned in another search on here) is that there are several Mules currently available. I've eliminated MT9 for my own reasons, but am having a hard time between MT12 Cruwear and MT13 Elmax.
I know Elmax is a stainless and Cruwear is supposed to be very tough, but I'd like to see some actual user feedback as to the pros and cons of each steel (taking an edge, holding an edge, etc.).
A note: I wouldn't be in this situation if I'd kept up starting with 52100!
When you start to get into these materials and learning more about them it begins to get a little nutty All are good, all will take a fine edge and keep it, the debates come up when you start splitting hairs :eek:
Get either or both :) Experience the blade material, enjoy and report back with your impressions :) We are lucky to have found Spyderco :D The Super Blue Mule has been very enjoyable for me as well as the M390 which has not been used enough yet :o .
Go for it, play, and test the limits :)
Charlie
Well I have both. I haven't used them much, but I say Elmax all the way based on my impressions. The Cruwear I have has some of the pitting described on other threads. It is very sharp, but I don't like the pitting. It bothers me. I'm not sure how it will effect the performance...probably not much, but the Elmax looks perfect and has a reputation for being very good steel.
Thanks to you guys, an MT13 is on its way :) Now I just have to get out of this apartment and back to the shop where I can put some real handles on it.
I gotta say, I've never had as good an experience as I have with Spyderco. It's definitely going to keep me coming back.
Chris
Chris
- xceptnl
Good snag Clip. I say if you ca swing the cash, get the Cruwear too. I didn't like the pitting at first, but it has grown on me alot. The steel performance is really great and responds well to stropping with or without compound. On a side note, the finish on the Cruwear (both perimeter machining and surface) is a really briliant semi-mirror shine. The more I use it the more I really want to order a second to keep in case.
I might pick it up once I get the Elmax in my hand. Have a feeling it'll overcome me like some kind of hunger after I get the first one.
Wouldn't happen to be from Franklin, would you?
Chris
Chris
Just last August I graduated from Tech and moved away from Salem (born and raised) to take a job here in Bowling Green, KY. Not the same without the mountains so I'm constantly keeping an eye out for openings :)
Glad to see something familiar once in a while.
Chris
Chris
- The Mastiff
That's a tough call. Cruwear is still a lot more rare. Elmax isn't very rare at all. It looks to be gaining in popularity so it'll be even more common. Cruwear you likely will never see again, and only run across it's name in steel lists and threads about the mule team project.Between the two, I'd go for Elmax. It's stainless and still VERY tough. I can almost guarantee too that it will end up being to more desired and harder to get once they're both gone.
Joe
I've got something in mind that's a little...different than what I've seen so far. Will post pics with progress eventually as I think it'll take a while.
And thanks to you enablers I'll probably order a cruwear tomorrow.
Chris
Chris
