Stretch 2 pivot screw washer size
PlungeGrind
Post by PlungeGrind »
Anyone know the size of the tiny washer that goes with the pivot screw on the stretch 2 k390? I seem to have lost mine somehow.
Thanks in advance!
cjk
Re: Stretch 2 pivot screw washer size
Post by cjk »
The Delica, Endela, and Endura all use the same washers. I'd bet the Stretch 2 does too. There are replacements available in the aftermarket.
I'm sure Spyderco can supply a replacement, but it's an internal part, so you'd probably need to send your knife in for service. I believe their policy is that they don't send out internal parts.
PlungeGrind
cjk wrote:
Wed May 15, 2024 7:52 pm
Thanks, do you know the washer size?
cjk
Post by cjk »
PlungeGrind wrote:
Thu May 16, 2024 5:50 am
not offhand, but here's where you can buy some.
https://www.knivesplus.com/replacement- ... ndela.html
iirc, there was a washer size thread on this forum.
PlungeGrind
cjk wrote:
Thu May 16, 2024 8:26 pm
Those are the washers for the pivot. I’m looking for the washer that goes on the pivot screw.
Have you disassembled a stretch?
cjk
Post by cjk »
thread about Delica washer size which I expect to be the same:
viewtopic.php?t=64451
quoted post with measurements:
Michael Janich wrote:
Mon Jul 21, 2014 6:48 am
Outside diameter 0.316"
Inside diameter 0.161"
Thickness 0.0035"
Stay safe,
Mike
Did you lose both? If you lost one, you could measure the other.
PlungeGrind
cjk wrote:
Fri May 17, 2024 6:00 am
Thickness 0.0035"
Stay safe,
Mike
Again I am not looking for a pivot washer, I am looking for the pivot screw washer. Do you l is what size the pivot screw washer is?
N. Brian Huegel
Post by N. Brian Huegel »
https://www.spyderco.com/service-suppor ... ty-repair/
Toll-free: 800-525-7770 X 3
customerservice@spyderco.com
:thinking Ask the source! This department was created to be of assistance.
nb
PlungeGrind
N. Brian Huegel wrote:
Sat May 18, 2024 7:35 am
nb
Yes, if they would only reply that would be great, but alas every time I email them, crickets.
Unfortunately customer service at Spyderco is becoming as subpar as BM.
cjk
Post by cjk »
Oh that washer! It appears to be sometimes included and sometimes not. I've had several K390 Delicas. Some of them had it and some of them didn't.
I do have a K390 Stretch 2.
I measured with a cheap set of digital calipers.
The washer is tiny. It's fairly difficult to measure, so these are approximate. I dropped it a lot while measuring. The thickness was the easiest to measure.
outer diameter (inches/mm): .224 / 5.5
inner diameter: .082 / 2.06
thickness: .013 / .32
It's the same washer as is sometimes on a Delica/Endura and sometimes not. Given that it's sometimes included and sometimes not, I wouldn't sweat too much that it's missing.
I compared the washer on my K390 Stretch 2 and the one on an old ZDP-189 Delica. They were the same as far as I could tell.
TazKristi
Post by TazKristi »
PlungeGrind wrote:
Sat May 18, 2024 2:20 pm
nb
Hi, PlungeGrind:
I checked with W&R, and they haven't received any emails from you (at least not from the email address you use on the forum). Please send me a PM with your contact information and I can have them check again.
Kristi
PlungeGrind
cjk wrote:
Mon May 20, 2024 2:28 pm
Awesome! Thanks for the info, that’s exactly what I was looking for. I had several disassembled at once so maybe I didn’t lose it after all.
Thanks a million!
