Anyone use Jet or Tormek slow speed sharpeners?
Does anyone use either the Jet or Tormek slow speed sharpeners to sharpen or reprofile their Spydies (or other knives)? Do you think either of these machines would do a decent job of reprofiling an edge? I am casually toying with the idea of putting an electric engine behind my sharpening efforts.
See article here for a comparison of the two machines.
Tormek user here; as I wrote in different other threads I like it a lot for reprofilling edges - fast & reliable. Only one disadvantage ... the price
Edit to add:
I recommend the big Tormek over the small Tormek.
Edit to add:
Spyderco's company motto
- Manix Guy 2
Lucky Me !
Best friend has a Tormek , so most of my knives when needed or wanting to try a different angle goes to Rick . He has offset the cost by sharpening knives for other people . MG2
- mrappraisit
If you are looking for a bunch of opinions or first hand experiences I would look for a woodworking or woodcarving forum and ask there. There would probably be way more owners/users of that machine on those kinds of forums. Hope that helps, they both look sweet BTW.
After enlightenment, the laundry.
Riot,
Your reply seems to say you don't sharpen your knives. Is that true? If you don't sharpen, you don't know what you are missing. As I have learned from this group, sharpen early, sharpen often.
I Like Sharp Things
Current Favorite: Caly 3.5, Super Blue. We're done here. It doesn't get better than the Caly 3.5
In my previous job i have used the older, green Tormek extensively, and in my current job i use the newer blue Tormek T7.
I use it to sharpen all kinds of customers knives, from little pocketknives to machetes, and also various kinds of scissors.
Next to this i sharpen completely new knives from certain well known brands that don't have an edge in the first place.
One of the biggest advantages of the machine is that you can create the exact factory edge using one of the knifejigs and a magic marker.
You can't even see that the knife has been sharpened.
Never needed to sharpen a new Spyderco by the way
I find the Tormek a wonderful machine to work with and one day i want one for myself.
No, I already know woodworkers swear by them...but woodworkers don't necessarily use them for knives. I'm looking for opinions on how they might work for sharpening fine cutlery, like Spydercos. I find cutting the backbevels very tedious to do by hand. I also know Spyderco makes their factory edges on a machine. Seems like they'd work well in theory, but I thought perhaps someone would post a "you idiot don't try it" message regarding some aspect I had not thought of.mrappraisit wrote:If you are looking for a bunch of opinions or first hand experiences I would look for a woodworking or woodcarving forum and ask there. There would probably be way more owners/users of that machine on those kinds of forums. Hope that helps, they both look sweet BTW.
:spyder: :spyder: :cool: :spyder: :spyder:Never heard of them; Thanks for sharing :)Bolstermanic wrote:Does anyone use either the Jet or Tormek slow speed sharpeners to sharpen or reprofile their Spydies (or other knives)? Do you think either of these machines would do a decent job of reprofiling an edge? I am casually toying with the idea of putting an electric engine behind my sharpening efforts.
:spyder: :spyder: :cool: :spyder: :spyder: "Spyderco...does a pocket good":spyder:
Spyderco Rocks!!!! "A wise man once said all knives were created equal...Obviously, he meant Spydercos''
As of 1-29-08, I am a proud member of Knife Rights!
- mrappraisit
Cool :) If you end up with one let us know how it works.Bolstermanic wrote:No, I already know woodworkers swear by them...but woodworkers don't necessarily use them for knives. I'm looking for opinions on how they might work for sharpening fine cutlery, like Spydercos. I find cutting the backbevels very tedious to do by hand. I also know Spyderco makes their factory edges on a machine. Seems like they'd work well in theory, but I thought perhaps someone would post a "you idiot don't try it" message regarding some aspect I had not thought of.
I have a 4" Bosch belt sander fitted to a Veritas grinder tool rest which I use for axes, machetes, and such...but I never considered using it for fine cutlery because I was uncertain of how much heat it generated. The belt sander does not have variable speed.Cliff Stamp wrote:Buy a belt sander for $50, use 50 grit belts, much faster than a Tormek for shaping.
-Cliff
Do you think it would be safe to set the back bevel with this setup, or would the blade get too hot? That's my big concern.
- Big footed nick
Do a search on Steve Bottorf the author of Sharpening Made Easy. He has a Tormek along with a bunch of others & can put a seriously sharp blade on a knife in a short time with a $30 Harbor Freight belt sander & a $40 Harbor Freight buffer with paper wheels. Or Utube with J Neilson just using a belt sander.
