Chief with compression lock?
I love the Millie so I never got a Native Chief. The Chief carries so well that if it had a compression lock, I would get a few. What day you?
Mule Team Army 001
MNOSD 008
MNOSD 008
Re: Chief with compression lock?
I feel like the handle is too narrow in height to work well with a compression lock. Back lock is perfect for that knife.
15 's in 10 different steels
I like the looks and feel of the lockback on the Native Series. Just makes good clean lines. Also makes for great ergos. I think the only thing I would change in regards to the lock is adding a boye dent. You can squeeze it tight and feel the blade wiggle. Outside of that, it is such a solid lock up and maybe the easiest lockback to operate in my opinion. I would hate to see that go.
I also do understand the larger market may have a different opinion. I would never fault Spyderco for making a change that is better for their business. It is not like it is an ethical decision or something. I would not loose sleep if they ended up changing it, but it would not be in my preference. I think the compression lock is a fantastic lock. Have it in several models. I also think that Spyderco makes a fantastic lockback. Fantastic in that you can easily manipulate it one handed.
I prefer a lockback to the compression most of the time, love the natural self close attribute without the need of a detent ball lockbacks bring
Current “dream collection” of knives
temperance 1, lil temperance 1 serrated leaf, black micarta calypso jr & calypso, cocobolo kopa, stainless serrated harpy, stainless cricket
I'm happy with it as is. I'd most likely pass on a compression lock version.
I like the back lock on the chief.
MNOSD member #0035
MNOSD member #0035
Kapara and IKuchi are extremely narrow compression locks. It most likely could be done.
I guess I like the diversity between the lock types of different series. Part of why I like seeing different sizes within a series, so a variety of people can try something that fits them size wize in that series.
I would hate to lose the Golden Mid lockback. I feel like we already lost the Golden Linerlock.
Here is a comparison photo of my Native Chief behind my PM2. It looks like the handle of the Chief is similar to that of the PM2 in this area. If that is the constraint, it should fit in that handle.
I feel the same as OP, even though I recognize these valid points about handle thickness perhaps not being wide enough for the comp lock, or the mid-backlock simply being too good to need improvement. But the comp lock is far and away my favorite, and important to me feels like the safest lock for keeping your fingers out of the guillotine. It is in fact the main reason I haven't sprung for a chief yet, as literally everything else about it feels perfect for me: the longer cutting edge, the long distal taper, the fine tip, the profile... Truth be told, I may fall for a new Magnacut LW Chief, but I find it hard to imagine I won't wish for the comp lock every day I carry it.
I don't find there to be any guillotine issue with the Native Chief. The choil and nub touch my fingers first when closing in the same way as my Chaparral shown here.
In that way, I find the back lock functions just fine and I'm okay with it. But, like some, I may like it even more with a compression lock.
The compression lock on the Lil Native functions well. The compression would work on a Native Chief without issue. It is an extremely versatile lock. I wouldn’t necessarily be in favor of a compression lock Native Chief though. I do tend to agree that the backlock is about as good as it gets on the Native Chief.
In my opinion, adding a compression lock Native Chief would start spreading the catalog too thin. It wouldn't end there either because the Native 5 will inevitably need a compression lock variant too. I already see frequent requests for that on social media. Theres no telling where it goes from there.
If their production capacity can handle the increased number of variations after the expansion is completed, it might not be such an issue but I just can’t help but to see it as counterproductive to add so many simple variations. It just produces an overwhelming number of options and it can be difficult to feel satisfied with your choice without feeling like another option would have been better.
It’s the “Too Many Options Paradox” and I believe we already saw this play out to some degree with their wharncliffe models. They just added way too many options and ultimately couldn’t support them all through sales. I’m probably overthinking it like usual but that’s what keeps me coming back…
- Nick
Even though I like compression locks, I personally do NOT think the Chief would be better with a comp lock. The Chief's back lock (and properly-made back locks in general) is one of the best locks on the market.
There's more than one way to skin a catbarnaclesonaboat wrote: ↑Thu Nov 02, 2023 12:42 pmI feel the same as OP, even though I recognize these valid points about handle thickness perhaps not being wide enough for the comp lock, or the mid-backlock simply being too good to need improvement. But the comp lock is far and away my favorite, and important to me feels like the safest lock for keeping your fingers out of the guillotine. It is in fact the main reason I haven't sprung for a chief yet, as literally everything else about it feels perfect for me: the longer cutting edge, the long distal taper, the fine tip, the profile... Truth be told, I may fall for a new Magnacut LW Chief, but I find it hard to imagine I won't wish for the comp lock every day I carry it.
https://streamable.com/gfhxo
Chief works well with the last method due to no boye dent. Comp locks are easier to swing open and shut, but with a little practice it's possible with nearly all the lockbacks Spyderco sells.
Personally I use method #2 and have been doing it that way since I got into Spyderco. 20 years without cutting myself, so it feels safe to me.
The blade geometry couldn't be more different, but the Amalgam feels really similar to the Native Chief in hand and pocket.
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
18 Spydies, 15 steels
13 Maxace, 9 steels
13 Maxace, 9 steels
- Buddafucco
I would LOVE a Compression Lock Native Chief! But I feel like I remember Sal already shot this idea down.
However, Spyderco never says never.
•• Beau
One of the design features highlighted in Spyderco's ad copy for the Native Chief is the linerless construction. A compression lock requires some kind of liners; even the Para3 lightweight has minimal liners. Putting a compression lock in a Native Chief would eliminate one of the main design features of the knife.
That doesn't mean a longer/narrower spear-point knife with compression lock is a bad idea. Maybe a "flattened" version of the Shaman or Bodacious could fill that role.
As Vivi has pointed out already:
The backlock is perfectly safe for the fingers, in fact imo more so than a comp.lock.
- For one a backlock can be closed with that "fingers always out of the blade path method" just like a comp.lock (completely unnecessary though imo with both lock types)
- And with other methods of closing a backlock one handed (and there are quite some, see three of them in the vids at the end of my post) the feature that the blade normally remains relatively solid in the half closed position enhances "safety"
Now since a backlock is also safer in pocket (much stronger self closing bias) and makes for better ergos (no potentially "hotspotty" comp.lock cutout) and can be better operated with gloves... for me personally it is no question that I way prefer a backlock Chief over a potential comp.lock Chief (even more so since the Native backlocks are so extremely well executed
https://streamable.com/j7fjd
https://streamable.com/bhhzs
https://streamable.com/myzlt
Sure it could be done, actually a comp.lock knife can be made with a "less tall" handle than a backlock knife for the exact same blade height as far as I can see (since with a backlock blade and lockbar have to fit on top of each other into the handle when the knife is closed)
I think what Rick meant is that in a narrow handle a comp.lock does not "work" / feel well in operation.
That´s what I found with my Kapara - narrow handle, small cutout - not great in use..
Chief is not 'my knife', but the Rex45 one I had was so incredibly well made - the lock was smooth and solid. It would be a shame to swap it for a compression lock. It is one of the best back locks I ever used and on par with my Cruwear Ayoob.
... I like weird ...
