I had enough of Seki ''hiccups''
When you pay 200¸+ euros(dispatch included) for a knife you don't expect to see these ''grooves'' on the edge. The new released C07S Police was one of my most anticipated spydies in years and when I saw this I was so pissed. I said it before, Spyderco should do something about the QC in that Seki plant. I understand the concept of loyality as much as the next guy but I guess the customers should come first. After all you would expect a higher level of quality when it comes to machining and attention to details when you purchase a ''made in Japan'' item.
Marius
( Rabindranath Tagore )
Re: I had enough of Seki ''hiccups''
Looks like your serrations are serrated! While that would not bother me, I can see how it could bother others. Especially if you have to pay so much more to get one.
I wonder how those perform? Even more snaggy than the typical serrations, or do they just shred through even more efficiently?
15 's in 10 different steels
Those look intentional. The serrations are micro serrated. I would imagine it would contribute to longer life for the factory edge.
Cut something and see how it goes.
That would take all of 90 seconds to smooth out on a sharpmaker.
all the more reason to be upset about it, i suppose.
i'm not sure this edge would bother me on a serrated knife personally, but i know what it's like to bring up a concern (especially about one of the seki factories) and have everyone justify it or treat the bug like it's a feature. i haven't had any problems with the standard seki line, but i have had, and have seen, problems with many of the non-standard seki knives, like the ayoob, the cruwear stretch xl, and let's not forget about that cf dragonfly that came out a little while back. kind of crazy that these issues are just ignored.
eh, I look at it like a loose clip screw. should the knife come like that from the factory? no. does it take longer to complain about it here than fix it? definitely.
Bluntly, you have no legitimate reason to complain. Pictures were posted, as early as October 2021, showing the edge on the SE K390 Police 4 lightweight to look exactly like that and, up until now, no one has suggested it is a manufacturing flaw.
viewtopic.php?f=2&t=90767&hilit=K390+Po ... Serrations
Really ?! I read that thread so what ? Did you ? Those comparative pics speak on my behalf . I am a 62 old mechanical engineer and I could teach you a thing or two about grinding and machining. This has to do with the cutting wheel they use and the way they do it. It's all about consistency. Oh and yes I have ''the legitimate reason'' to complain because I spent 230 to purchase this knife and all the other (older) 4 C07S that I own have clean grinds with no ''grooves'' so it can be done.dsvirsky wrote: ↑Fri Jun 09, 2023 9:20 amBluntly, you have no legitimate reason to complain. Pictures were posted, as early as October 2021, showing the edge on the SE K390 Police 4 lightweight to look exactly like that and, up until now, no one has suggested it is a manufacturing flaw.
Marius
I'm sure you know more about machining and grinding than I do. My point is you knew, or should have known, what the serrations were going to look like before you purchased the knife.
I own four more older C07S and none have this ''issue''. I did some comparative cuts and it you can feel a difference. It doesn't snag but it's not as smooth as the others.
Marius
the more expensive a knife, the more irritating things like this are. the more rare a knife, it's exponentially worse. you can't just return a sprint or exclusive for a replacement (and when spyderco themselves suggest this, it's just insult to injury). those, specifically, should be given the strongest qc inspection of all because of that. but i digress...
the number of issues happening in seki should be addressed. if people just shrug off the problem, as you are suggesting, spyderco might not know the extent of the problems. they need to know so they can deal with it. of course, from what i've seen, it looks like they are more interested in making excuses for seki than holding them accountable, and that's made worse by forum members dismissing problems as no big deal. even if it's an easy fix for you, it might not be for everyone, and no one should ever have to do anything with a $200 knife before they can stick it in their pocket and go.
We all like to be the white knight in shining armor coming to the rescue, but let us at least try to be polite about it. That said, Spyderco doesn't need anyone to be a white knight for them as they are fully capable of defending and/or explaining product issues.
Those grinds* make the knife look unfinished, IMO. Sure it probably performs as intended, maybe slightly better, but it looks bad. Humans are visual creatures, so looks matter to varying degrees depending on the person.
The Japanese makers need to up their game, IMO.
* Yes, I understand that K390 is more difficult to finish versus many other steels in use.
i think what he's getting at is that the machining they use on k390 is different from what they use with vg10, which makes sense. that doesn't necessarily mean it has to be more rough, but that's the way these edges were produced and we've known about it for a long time now. that doesn't mean that you don't have a leg to stand on in your complaint... it just means that consistency might not be the best argument between two steels that perform vastly different because of vastly different properties.elena86 wrote: ↑Fri Jun 09, 2023 10:12 amReally ?! I read that thread so what ? Did you ? Those comparative pics speak on my behalf . I am a 62 old mechanical engineer and I could teach you a thing or two about grinding and machining. This has to do with the cutting wheel they use and the way they do it. It's all about consistency. Oh and yes I have ''the legitimate reason'' to complain because I spent 230 to purchase this knife and all the other (older) 4 C07S that I own have clean grinds with no ''grooves'' so it can be done.dsvirsky wrote: ↑Fri Jun 09, 2023 9:20 amBluntly, you have no legitimate reason to complain. Pictures were posted, as early as October 2021, showing the edge on the SE K390 Police 4 lightweight to look exactly like that and, up until now, no one has suggested it is a manufacturing flaw.
What are you talking about ??? Two weeks ago I bought a SE Stretch XL and the edge is silky smooth. We are talking consistency here ! Those ''grooves'' shouldn't be there ! It's not a feature, it's a grinding flaw.
Marius
Every sprint run Chief I bought, I purchased two.ladybug93 wrote: ↑Fri Jun 09, 2023 10:29 amthe more expensive a knife, the more irritating things like this are. the more rare a knife, it's exponentially worse. you can't just return a sprint or exclusive for a replacement (and when spyderco themselves suggest this, it's just insult to injury). those, specifically, should be given the strongest qc inspection of all because of that. but i digress...
I'd inspect them both and sell off the one that had the lock release sticking out from the handle the most.
I kept the better ones, but they're not 100% perfect.
It's the nature of mass produced knives.
The latest Ladybug Hawkbill I received (online only because my local shop has none) was hands down the worst of the previous 3 I have owned. The tip is a bit wonky and the serrations aren’t near as “new” feeling as others. That said, it’s my ocean/pool knife so I am letting it go. Probably hit the sharpmaker eventually but seems like a good thread to add slight dissatisfaction on a Seki knife.
