Compression Lock Patent - Expired?
I looked up the Spyderco's patent for the compression lock and it appears that it expired on 2/22/2021. Does this mean that any of the other knife makers can start using the compression lock? And if so, when would we expect competitors to start popping up with their own rendition of the compression lock?
Re: Compression Lock Patent - Expired?
It is no longer protected by patent, but that doesn't make it any easier to manufacture.
- dj moonbat
Yeah, the real protection from knockoffs is that it’s just hard to make.
- kennethsime
I'll bite: what makes the compression lock so hard to get right? Is it harder than a good liner lock?yablanowitz wrote: ↑Tue Mar 30, 2021 6:51 pmIt is no longer protected by patent, but that doesn't make it any easier to manufacture.
- Stuart Ackerman
Carefully thought out geometry is what make the Comp Lock the best IMO
I wouldn't say it's any harder than any other lock to get right. As long as the geometry of the lock face is good (and spyderco seems to have it dialed in, obviously) I would think it would be pretty easy to reproduce. I think it's a cost thing. Liners, frame locks, the axis lock, they all contact a single surface, the tang of the blade. The compression lock contacts 2, the tang and the stop pin. Getting all of that correct, with no play, no stick (or very little), and a strong lock, in a mass production environment... I think it's a pretty amazing feat.kennethsime wrote: ↑Tue Mar 30, 2021 10:06 pmI'll bite: what makes the compression lock so hard to get right? Is it harder than a good liner lock?yablanowitz wrote: ↑Tue Mar 30, 2021 6:51 pmIt is no longer protected by patent, but that doesn't make it any easier to manufacture.
I just think people have tried and don't like the challenges. I remember when the axis lock patent expired and there were knives just waiting to get produced. Doesn't seem so with the comp lock!
Spyderco : Resilience, Tenacious, Persistence, Manix 2 G10, Para 3 G10, Para 3 LW, Paramilitary 2,
- curlyhairedboy
I'd love to see more custom makers using it. We'll see what happens!
I wouldn't worry about it. The back lock isn't patented (actually I dunno is it?) but Spyderco still make the best I've ever used. It's one thing to be legally allowed to make a compression lock, it's another to make one that works well. Even if brand X makes a BETTER compression lock, there's still the matter of ergonomics/steel/customer service that will dictate what I buy long before the lock design does. The Tri-Ad is one of the best locks available but I don't care for the designs it comes in, but if Spyderco were to say...make a Sage with a Tri-Ad lock... it would definitely grab my attention.
- curlyhairedboy
I'd be interested in a Demko design with a compression lock.
Good liner locks aren't all that common, either, but yes, the compression lock requires precision to work correctly. Of course, it could be slapped together like most liner locks and be less likely to fail than they are, with the same outcome - people avoiding and bad-mouthing them the way they do liner locks now.kennethsime wrote: ↑Tue Mar 30, 2021 10:06 pmI'll bite: what makes the compression lock so hard to get right? Is it harder than a good liner lock?yablanowitz wrote: ↑Tue Mar 30, 2021 6:51 pmIt is no longer protected by patent, but that doesn't make it any easier to manufacture.
What makes it difficult is multiple points of contact. Has to be precise because you have a balance of too tight or too loose and it won't work right. Spyderco had issues with manufacturing in the past. Here's what it looks like from the side. Not much room for error. Seems simple enough though.
Lifting a car engine is simple. That doesn't make it easy.
I totally agree. I was just saying that just looking at it without knowing it seems simple.yablanowitz wrote: ↑Wed Mar 31, 2021 9:32 amLifting a car engine is simple. That doesn't make it easy.
One thing I came to realize long ago is that often the things that appear simple are, in fact, quite difficult to do well or get it right. This applies to many things.
Not to imply that Spyderco should or could improve on their comp lock, but judging by the expiration of the axis lock patent, there seems to be more upsides than downsides. At least to me, it seemed like Benchmade upped their axis lock game around the time the patent expired, which has lead to me buying more Benchmades after the expiration than before - and as of yet, non of the competing implementations.
Hey Curlyhaired boy,
I don't know if Andrew Demko is tied to Cold Steel and what the arrangement is. I don't think we'd be opposed to working with him, but he would probably have to approach us.
- RadioactiveSpyder
I have a most excellent compression lock Pulsar made by Jesse Jarosz probably six or more years ago. Custom makers could use the comp lock if permission was granted from Spyderco (which it was, in fact I recall a hilarious conversation between Sal and Eric about it when I showed it to them at an OKCA show years ago), just like makers request to be able to use the Spyderhole in any designs. So, it’s not as if that lock was never available for use by other makers (although I’d likely bet that a full-sized knife company wouldn’t have been granted permission). Jesse Jarosz’s take on it is spot on, and his liners are a bit thicker even. Cheers, Radioactive
Sage 6: Shark Lock!
- kennethsime
Thanks guys, great explanation. Just goes to show that Sal + Crew have got it together.
The Vosteed Mayhem is evidently using a button actuated compression lock. It appears similar to a Smock.
