Spyderco Pacific
Spyderco Pacific
I'm looking at this knife but can't decide between the plain blade and serrated. It's intended use is for fishing. Do any of you have a preference between these to blade types and if so why.
Re: Spyderco Pacific
Welcome to the forum FLHTK!
I chose the serrated edge, because apparently H-1 performs best in that form. My intended uses were for general EDC but also for hard use as an outdoor/gardening knife. In that capacity is has no equal.
You will probably need to touch up plain edge H-1 a bit more frequently than SE, but if you're not using it super hard all day, even PE H-1 ought to last you a good while.
I guess my recommendation is, if you will be using this knife frequently for tasks like cutting brush, or prolonged hard use, go with the serrated version. If it's just going to live in your tacklebox and only occasionally see mild use like cutting fishing line, PE will be most likely be quite adequate.
Do you have a personal preference in edge type?
- Connor
If you plan on cutting fishing line, SE is better in my opinion. If you plan on gutting fish, PE for sure.
If you're a fisherman, I vote for the SE Salt and the Waterway! Best of both worlds.
15 's in 10 different steels
- PeaceInOurTime
Excellent shot!
To the OP, I don't have experience with H1, but don't be afraid of serrations. I've used my Byrd Rescue 2 quite a bit as a primary blade and it hasn't let me down. Honestly, plain edge is my preference, but I will likely carry a plain edge and a serrated edge together for the foreseeable future.
I'm probably going with the Pacific in SE. Seems to be the one that will do what I want it too. Thanks for all the relies.
Most "knife people" will tell you PE H1 dulls fast (read knife forums)
Many "normal people" will tell you PE H1 holds an edge (read Amazon's reviews).
PE H1 dulls faster than today's "quality standard steels", that's a fact. But it isn't butter soft and it's super easy to sharpen.
Both work great. Serrated will hold an edge a little longer, but either type makes a great pocket knife to keep with you every day. Can't go wrong eith either.
I’ve been going back and forth with this same decision lately as well. I went with SE and it’s on the way right now. I will most likely get a native salt PE to pair it with on the water. I have a SE Endura 4 that is a dedicated work knife and I can tell you there’s never been a time I wished I had a PE instead. Spyderco’s serrations are one of a kind, they increase the performance of the knife so much IMO. They can cut through **** near anything.
agreed. and the native salt pe and pacific salt se do make a nice pair. here they are together in the crystal clear hawaiian waters.T-1000 wrote: ↑Fri Apr 12, 2019 8:01 pmI’ve been going back and forth with this same decision lately as well. I went with SE and it’s on the way right now. I will most likely get a native salt PE to pair it with on the water. I have a SE Endura 4 that is a dedicated work knife and I can tell you there’s never been a time I wished I had a PE instead. Spyderco’s serrations are one of a kind, they increase the performance of the knife so much IMO. They can cut through **** near anything.
Great picture! And thanks for sending me over the edge now I MUST get the native salt :pladybug93 wrote: ↑Fri Apr 12, 2019 8:25 pmagreed. and the native salt pe and pacific salt se do make a nice pair. here they are together in the crystal clear hawaiian waters.T-1000 wrote: ↑Fri Apr 12, 2019 8:01 pmI’ve been going back and forth with this same decision lately as well. I went with SE and it’s on the way right now. I will most likely get a native salt PE to pair it with on the water. I have a SE Endura 4 that is a dedicated work knife and I can tell you there’s never been a time I wished I had a PE instead. Spyderco’s serrations are one of a kind, they increase the performance of the knife so much IMO. They can cut through **** near anything.
- SpyderEdgeForever
Let me put it this way, my friend. The Spyderco Pacific Salt, Serrated-Edge, is so toothy sharp, it makes tiger sharks pee tuna juice when they see it.
I have the SE Pacific and it’s an awesome knife. If you are using to cut up chunk bait the SE goes through a whole fish like a laser! All 5 of my H1 knives are SE.
I just picked up the PE Native 5 Salt LC200N so I’ll have that too.
SpyderEdgeForever wrote: ↑Sat Apr 13, 2019 3:52 amLet me put it this way, my friend. The Spyderco Pacific Salt, Serrated-Edge, is so toothy sharp, it makes tiger sharks pee tuna juice when they see it.
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
I think if I had purchased the Pacific Salt SE or for that matter any one of the Salt Series of knives, as my first knife, I would have far fewer of other brands and types knives and would have a drawer full of Salt Series blades.
the majority here are right
Pacific SE is all you could need and wish for :o
