TESTING thread.
TESTING thread.
I am creating this thread so we can post to test things, like signatures and avatars.
It appears the signatures are off by default, we'll see if I can turn it on in one try. I see a check box below this post.
-Brian
A distinguished lurker.
Re: TESTING thread.
Test.
- Attachments
- Test
- CF-Dodo.JPG (163.21 KiB) Viewed 8748 times
-Brian
Re: TESTING thread.
It looks like to turn on Signatures by default you have to go
1. User Control Panel (top left under the logo)
2. Board Preferences (at the top)
3. Edit Posting Defaults (on the left under the row containing "Board Preferences")
4. Attach my signature by default: Yes ( A circle selection next to Yes. )
-Brian
- xceptnl
Re: TESTING thread.
Also notice the new format has tighter restrictions on character count for signatures. Had to shorten mine :D
Re: TESTING thread.
I wonder if you could save characters on your image with tinypic.
I believe that some forums think being able to "img" to other sites is a security risk.
-Brian
Re: TESTING thread.
Testing 123. :eek:
- The Deacon
Re: TESTING thread.
Based on my own sig line, I suspect that characters inside {URL} and {IMG} tags don't count against the 255 character limit.Donut wrote:I wonder if you could save characters on your image with tinypic.
And it only allows 3 URL links. Had to delete a couple from mine. :oxceptnl wrote:Also notice the new format has tighter restrictions on character count for signatures. Had to shorten mine :D
Also, FWIW, just noticed that, while there's no "multi-quote feature, if you're quoting one post and hit the quote button on another, the second quote will be added to your editor.
Re: TESTING thread.
Can someone tell me how to, if it's possible, to post a video like before without the URL link?
- best wishes, Jazz.
Re: TESTING thread.
Testing new coding to embed YouTube and Google videos. See new buttons in the editor.
Re: TESTING thread.
And another...
- The Deacon
Re: TESTING thread.
TazKristi wrote:Testing new coding to embed YouTube and Google videos. See new buttons in the editor.
Not quite as easy to use as the old system where you just copied and pasted the entire URL, so it's probably going to be a bit more of a challenge for members without at least a bit of geek-fu :p but it works. Same is true for a few other things as well, (EXAMPLE: align= needs the user to input left, right, or center manually, font= requires you to supply a font name).
Re: TESTING thread.
The Deacon wrote:TazKristi wrote:Testing new coding to embed YouTube and Google videos. See new buttons in the editor.
Thanks Kristi and Paul!
Re: TESTING thread.
Well, that doesn't work.
-Brian
Re: TESTING thread.
Test for sig.
Also, how do I embed a You Tube vid with the button in the editor since directly pasting the embed code no longer works?
-Jodi
It's not just in my head, it's in my heart.
- 3rdGenRigger
Re: TESTING thread.
Use the bit after the "v=" in between what the button posts to your reply window. I'll include the raw link, and embed it as an example.1623 wrote:Test for sig.
https://youtu.be/bKHz7wO ... n9QU6phsgw" target="_blank
All Glory To The Hypno-Toad
---> Branden
---> Branden
- 3rdGenRigger
Re: TESTING thread.
This was what I was told and it has worked some of the time, but only seems to work some of the time so don't hold me to it...I've tried it today and it doesn't seem to work.3rdGenRigger wrote:Use the bit after the "v=" in between what the button posts to your reply window. I'll include the raw link, and embed it as an example.1623 wrote:Test for sig.
---> Branden
---> Branden
- 3rdGenRigger
Re: TESTING thread.
No problem...though as in my above example it only seems to work some of the time, so don't be surprised if it doesn't work some of the time. I'll post back with an update if I can figure out why that is.
---> Branden
---> Branden
