polishing endura clip?
chuck_roxas45
Post by chuck_roxas45 »
i have an endura FRN with the black clip, is there any way to polish the clip so it would look like stainless steel? can i just use metal polish to strip the black coat off?
VashHash
Post by VashHash »
You'll probably have to use somehting abrasive and then move on to metal polish thats how i usually do it. Wire wheel or Scotch brite pad and then dremel with cloth wheel and jewelers rouge.
chuck_roxas45
mucho thanks vashhash.
Toad310
Post by Toad310 »
Do this, and it will look like it came from Tiffany's
Here is what I did, and it looks the same as the polished clips.
1. Get a spray can of paint remover from hadrware store Spray some on wait a few minutes and rinse and dry clip.
2. Rub with a Scotchbrite pad
3. Then use some 800 grit sand paper, and finish with 2000 grit.
4. Use some metal polish.
Done! You can buy all of the things for this at Wal-Mart
The paint will wipe right off the clip with the paint remover.
Total time it took me: 30 minutes.
Use some rubber gloves while using the paint remover.
Good Luck!
chuck_roxas45
sounds much better, thanks. BTW does the clip rust?
Post by The Deacon »
Pays to keep in mind that, with the exception of H-1 and similar "exotics" that are technically not even steel, "high end" stainless blade steels tend to be far less "stainless" than the types of stainless steel you find in handles, hardware, and clips. That stuff is about as rust resistant as the stainless used for tableware.
When's the last time you found rust on a spoon, fork, or table knife? Those things occasionally get dumped in a sink coated with food that's saltier than the ocean and acidic for good measure. They are sometimes left there for hours, or even days if you're as bad a housekeeper as me. :eek: After they finally get washed, they're sometimes left to air dry. And nobody ever worries about what to coat them with to prevent rust. ;) :D
chuck_roxas45
oh ok I guess this clip gets polished. and I thought I had miracle saliva when my stainless knives and guns rust and my .50 cent spoons don't. thanks again Deacon.
Toad310
Post by Toad310 »
chuck_roxas45 wrote:sounds much better, thanks. BTW does the clip rust?
Mine never have, and if they ever did, just polish it off with metal polish, or any number of things.
I doubt it will rust.
Go for it, they look wonderful polished. I do not like the black clips.
sharpguitarist
Post by sharpguitarist »
i used acatone to remove the black paint from my clips. i just soaked a paper towel and gave it a quick rubdown. with a little care, you can leave the black in the spider, which looks pretty cool. i didn't polish mine afterwards, i like the factory sandblasted finish underneath, and its not so obvious against feded jeans.[url=http://Image]http://Image[/url]
prime77
Post by prime77 »
A big thank you to sharpguitarist. I took some acetone to my clip and made it look like this. I kinda of like the sandblasted look against the green. I'm not sure if I polish it up or not.
Toad310
Post by Toad310 »
What you can polish is the underside of the clip so it slides in and out of your pocket nice and smooth. Just a light buff with the brown Scotch Brite.
Looks good, I like that look, too.
You can add the black in with a sharpie, then lightly re-wipe with acatone.
sharpguitarist
glad you like the way it looks prime! :D glad i could help, even if i did spell acetone wrong! your knife looks awsome.
Simple Man
Post by Simple Man »
Good thread on the issue. Kleen Strip stripper used - WM.
http://spyderco.com/forums/showthread.php?t=35093
And mine, I used a Sharpie on the logo and rubbed the extra off with my thumb, it has held so far.
Romans 8:31 ....If God is for us, who can be against us? - <><
The Spyderco hole is a rotating mechanical assembly of one part.
".....tractors don't have to look like Ferraris" -Sal
Glock27
Post by Glock27 »
You could order a clip for the Adventura - C102 it's stainless steel and will fit the Endura...the screws won't, but the clip will.
G27
Outlet Store #800-525-7770 ext 107
"Good judgment comes from experience, and a lot of that comes from bad judgment." - Will Rogers
Toad310
Post by Toad310 »
sharpguitarist wrote:glad you like the way it looks prime! :D glad i could help, even if i did spell acetone wrong! your knife looks awsome.
I have seen it spelled both ways, you can google it.
MIKE ROBINSON
Post by MIKE ROBINSON »
Use a black sharpie over the bug wipe off excess looks great
jzmtl
Post by jzmtl »
You can also use china marker, they come in different colors too.
bodydamage
Post by bodydamage »
I bought some "Extra Strength" "Heavy-bodied, semi-paste, paint, varnish, and stain remover" from ACE and sprayed the clips on my Para and Native with it and it didnt even pretend to touch the coating.. I ended up letting it sit on there for 4 hrs and it didnt phase it..
http://www.acehardwaresuperstore.com/ac ... -2987.html
Whats the deal?
sharpguitarist
i tried a couple of things that didn't work: my wifes fingernail polish remover and clear brake fluid, neither worked after a long soak. straight acetone took it right off!
Simple Man
