Can a Delica 4 be opened with centrfugal force?
I am in Canada and can only get the ZDP from the states, but many knives as you all know are confiscated due to the centrifugal force bullsh.. I mean issue.
Can this knife be opened with a flick or is the blade not heavy enough? I don't even want to risk it getting confiscated.
Any Canadians order any delicas from NewGrahamKnives with any border troubles?
Thanks
Thanks
there is no such thing as the force of which you speak(sorry, physics gripe)
centripetal acceleration is a center seeking acceleration exhibited by a rotating object.
aka marauder2002 www.marcymotorsport.com www.focuschallenge.com
- dalefuller
Not mine...
The last D4 I bought was just before Christmas. It was a ZDP-189 D4 that I got off the 'Net but not from NGK. It was pretty stiff. I didn't try to flick it open, but I don't think that would have worked.
I have had very good results from talking on the phone to the people at NGK. As someone has suggested, they would probably help with this by tightening down the pivot screw some before they ship to you. Then you could loosen it before you open the knife the first time. Just make sure you have the right size Torx driver.
Regards,
Dale
"If there are no dogs in Heaven, then when I die I want to go where they went."
~ Will Rogers, 1879-1935
Dale
That stupid law is popping up everywhere. :mad: They just try to get rid of the folder but they can't. So, they came up with this stupid one. I can flick open almost any spyderco folder by holding the handle except my own S30V Native. However, most of the spyderco folder can be flicked open by holding the blade right on the top of the opening hole.
Shifty wrote:I am in Canada and can only get the ZDP from the states, but many knives as you all know are confiscated due to the centrifugal force bullsh.. I mean issue.
Thanks
I've had no problems order from Newgraham. Customer service is top notch and they'll tighten down the pivots if you ask them. Nothing confiscated yet. Plus the delica is pretty small and light which makes it harder to flick open. I wouldn't worry. I ordered a civilian from them a couple of months ago with no problems.
- jimbo@stn24
Shifty,
I ordered a Delica 3 last year from NGK and it made it through along with another knife that had the pivot tightened. A Jess Horn was confiscated this Christmas by our crime fighting friends at CBSA however. Am not sure of the blade mass of a Jess Horn but it doesn't seem to be in the centrifugal or centripetal opening league of almost 4" blades. At any rate, NGK does a good job and best of luck if you go for it. :)
WTC #1455
- Capt. Carl
[quote="Joshua J."]Get the pivot tightened and it wont be a problem.
Now, the knife I’]
Flicking the lava open is IMPOSSIBLE. The spring is the tightest thing I have ever witnessed and the blade weighs nothing. DON'T WORRY ABOUT THIS ONE! :)
edit: I can flick all of my blades down by holding it in the reverse grip EXCEPT my lava. This blade is staying in there.
Now, the knife I’]
My SE VG-10 Delica 4 cannot be flicked open by merely holding onto the handle. My PE VG-10 Delica 4 can be flicked open by holding the handle.
I think laws that prohibit the so called "gravity knife" are absurd in spirit, ad hoc in there interpretations and arbitrarily and capriciously enforced.
As has already been alluded to, my kitchen knives provide for a more lethal implement for commiting assault and mayhem, and statistically speaking, kitchen knives are used in many more violent crimes than any 100-200 dollar manuel opening pocket-knife.
In many states, it is legal to carry concealed a loaded .45 auto with a round in the chamber, or a 5 inch fixed blade knife in a quick-draw scabbard, while in that same state it would be a felony for that same person to carry a 3 inch auto-knife or balisong. Unfortunately, there are many more unintuitive and unreasonable statutes in criminal law that make as much sense as the above analysis.
-Mike
-Mike
"Two things fill the mind with ever new and increasing admiration and awe, the more often and steadily we reflect upon them: the starry heavens above me and the moral law within me." -Immanuel Kant
"I do not worry about what will happen; only what needs to be done". -Lucious Hunt, "The Village"
- tonydahose
