Torx head size for Endura 4 pocket clip
Does anyone know what size torx head the three screws that hold the pocket clip on the Endura 4 are? Or where I can find a tool that small? The pocket clip on my Endura 4 is coming loose, and I can not find a torx head small enough to fit it. I have checked in Lowes, Home Depot, Wal-mart, and Sears, and the smallest I can find is T8. I don't want to lose my clip, or worse yet my favorite knife. Thanks.
the size is T6
"THE ROUGH RIDER”“FAR BETTER IT IS TO DARE MIGHTY THINGS..THAN TO TAKE RANK WITH THOSE POOR. TIMID SPIRITS WHO KNOW NEITHER VICTORY NOR DEFEAT.” THEODORE ROOSEVELT 1899
spyderco making mans oldest tool mans most advanced tool:spyder:
THE GREATSET POWER IS OFTEN SIMPLE PATIENECE
The only thing necessary for the triumph of evil is for good men to do nothing.
sears sells the size as well.
- The Deacon
As does Home Depot, it is one of the sizes in the small Husky multi-bit Torx driver set they sell for around $6.
- dalefuller
Lowe's, Home depot, or Sears all sell small Torx head drivers that fit into the handle and make a nice little package. I have the Husky and Kobalt sets. They were less than $10.00 each and both cover the range from T4 to T15.
I also have Benchmade's Blue Box and have had no trouble with it, but it is a little harder to set up for use since the box becomes the handle when it's assembled.
Regards,
Dale
"If there are no dogs in Heaven, then when I die I want to go where they went."
~ Will Rogers, 1879-1935
Dale
Assuming my trainer is the same as the knife, a T6 fits. Lowes sells an 8 bit set under their brand name Kobalt. Comes in a blister pack, and the drivers fit in the handle
If you anticipate getting a knife like the Yojimbo, which has Torx head on both ends of the screws, you might want to get two while you are at it.
Qship
Qship
Husky Tool!
I'll second the vote for that Husky torx set. It's a nice all in one with all the torx bit sizes you could need for modern folders like the Spydie line. A tip, if you pull out the plastic insert inside the handle all the torx bits will fit inside!
