Results 1 to 10 of 10
Thread: What exactly is an Eccentric Pivot Pin?
  1. #1
    Spyderco Forum Registered User
    Join Date
    Aug 2008
    Posts
    53
    i have a millie and a paramillie both made in 2006, both S30V and i am wondering if they have Eccentric Pivot Pins. it seems to have something to do with adjusting the lock clearances but im not sure what it really is or how it affects the knife?
  2. #2
    Join Date
    Dec 2008
    Posts
    10
    An excentric pivot pin allows frontward and rearward adjustment of the blade relative to a liner lock. It's used to adjust for wear in the locking mechanism and to adjust the fit for safe lockup.
    The mille does not have an excentric pivot pin - I've had one apart.
  3. #3
    Join Date
    Nov 2008
    Location
    Utah
    Posts
    935
    The earlier Militaries did have them, the current ones do not. I have a 440V Military that has it.
    Others that had it at one point or another were the Lil' Temperance and the Starmate (I think).
    I believe that Spyderco discontinued it's use around 2002, but that's just observation and nothing concrete.
    42 Spyderco fixed blades and counting...
  4. #4
    Spyderco Forum Registered User ClockWork's Avatar
    Join Date
    Mar 2008
    Location
    Lonetree Colorado.... south of Mecca
    Posts
    763
    "Eccentric pivot pin" Patent on Freepatentesonline.com
    http://www.freepatentsonline.com/6101723.html
    clock
    Favorites: Black Paramil w/ D2 blade, PE Mini-Manix, S90v Military, Civilian, SE Dodo, PE Police, Sage
    Vist my eBay store: Life and Liberty Gear
    Tactical & MOLLE gear, Headgear and more
    stores.ebay.com/Life-and-Liberty-Gear
  5. #5
    Spyderco Forum Registered User vampyrewolf's Avatar
    Join Date
    Sep 2004
    Location
    Fort McMurray, Alberta, Canada
    Posts
    7,478
    Eccentric pivots were used primarily on the 440V C36's (2000-2002 IIRC). It was a 12 sided egg-shaped pivot pin that allowed for adjustment over the life of the liner lock. Essentially you loosened off the pivot screw (with the knife closed), pushed the other side of the pivot out enough for the faces to be moveable and rotated a step left or right. Tightened the screw up and cycled the knife a few times to check placement on the lock. Moving it in moved the lock less across the tang. This allowed for a lot of range in behavior if done properly, and an unsafe knife if not done right (as you introduced blade play).
    Tolerances were tightened up with the S30V models and removed the need for the eccentric pivot.
    Coffee before Conciousness
  6. #6
    Join Date
    Aug 2008
    Posts
    53
    thanks for all the info guys!
  7. #7
    Spyderco Forum Registered User Free Radical's Avatar
    Join Date
    Dec 2008
    Posts
    137
    In case anyone needs to know in the future, the green Lums have an Eccentric pivot.
  8. #8
    Spyderco Forum Registered User J Smith's Avatar
    Join Date
    Sep 2004
    Location
    Harriman TN USA
    Posts
    7,081
    As has been said the pin stooped with the 440V Militaries but a very few of the first S30V Milis did have them.I had one.In a Milli if the pivot screw is a torx it should be a excentric pivot.
    0 0
    \____/
  9. #9
    Spyderco Forum Registered User Simple Man's Avatar
    Join Date
    Sep 2004
    Location
    Kentucky
    Posts
    2,036
    Yes, if it has a torx pivot bolt it also has an ecc. pivot, Hex head has a regular pivot.
    From Joyce re: Ecc. pivot pins.
    "There was a cross over time where we had started using S30V on the C36 and were still using eccentric pivots. We stopped using eccentric pivots early this past summer and the Military's pivot pin changed then to a "D" nut. It actually came about as an improvement in our manufacturing capabilities. The tolerances on parts used in the older Military were tight but we've gotten better. We installed an eccentric pin so the knife could be adjusted for any tolerances that were not absolutely spot-on precise. With recently upgraded machinery (and a really talented crew) in our plant, we're cutting parts to even closer tolerances eliminating the need for adjustment. Probably seems rather strange, but we're getting better at making 'close to perfect parts'.
    Joyce @ Spyderco"
    My S30V Millie was one of the first out had it had the Torx head.
    Romans 8:31 ....If God is for us, who can be against us? - <><
    The Spyderco hole is a rotating mechanical assembly of one part.
    ".....tractors don't have to look like Ferraris" -Sal
  10. #10
    Spyderco Forum Registered User Netsquash's Avatar
    Join Date
    Jan 2009
    Posts
    339
    Taken out of context I would say Woody Allen... :P
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
