Stripped screws or hole
Ever strip a hole or a screw when installing a new clip?
Re: Stripped screws or hole
Dear EarlyToRise:
Stay safe,
Mike
Stay safe,
Mike
- WilliamMunny
Stripped a screw, my fault, but being so small you can do it fairly easy. Called Spyderco and Mike took care of me, sent out new set of screws at no cost.
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
- apollo
Don’t know why but the clip screws are the only ones that have the risk of getting damaged in my personal experience when opening a knife to swap scales. I did once have a manix XL with a bad body screw but turned out it was the liner itself was the problem. Took some time but i was able to fix it. The knife came with a ton off blue locktide on that screw. So guess something went wrong there and someone tried to hide it.
There's a Youtuber that jokingly said in a video that he thought the SAL symbol on the knives stood for Soft screws And Loctite
