I ordered a Dragonfly for my wife and the hole is rather "edgy". My hands are tougher than hers, but even I noticed it. How would you ease that edge? I sorta did a search and didn't see anything, but I get side tracked easily....
It took Knifecenter 3 days to ship it, and then the Labor day weekend slowed it down, so I don't want to send it back and wait 3 weeks for her to get another one, but I don't want to wreck the looks.
Ideas?
Dragonfly Salt 2; Sharp Holes ?
Re: Dragonfly Salt 2; Sharp Holes ?
Lots of threads on this subject through the years.
viewtopic.php?t=43715
viewtopic.php?t=78376
viewtopic.php?f=2&t=91338
Thanks, I just didn't go back far enough. Told you I get sidetracked...mikey177 wrote: ↑Sat Sep 09, 2023 5:48 amLots of threads on this subject through the years.
I was thinking the coned sandpaper Idea would be perfect.
You're welcome. I often use Google to search through Spyderco Forum topics, as it gives me more refined results.
Good luck with your modifications.
Just ream it with a penny.
Worked like a charm on mine.
The sharp edges helps at deploying it.
I have a Spyderco with smooth edges which is more of a struggle to deploy.
I would keep the edges sharp or smoothen it only a TINY bit. Better less than more.
- WilliamMunny
My new Dragonfly Salt is the same way. I would not call it sharp but much more of an edge than my other models. It does seem to help deploy it on a smaller knife.
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
I take one of the rods from my Sharpmaker and stick it in the hole and run it around the edges. Sandpaper on a pencil will work, too.
