Yojimbo 2 pivot changes?
- bbturbodad
I'm doing a blade swap, putting the DLC M4 blade into my CF 20CV and noticed a difference in the pivots between the two. Anybody know why the DLC M4 (right) has a groove down the center?
-Turbo
Re: Yojimbo 2 pivot changes?
A place for grease?
I don't know.
I don't know.
- Connor
- bbturbodad
That's my thought too... I'll probably swap it over with the new blade.
-Turbo
Extra groovy? :D I didn't notice when I swapped my M4 and S90V, I'll have to take a closer look next rime I have them apart.
Some advice... Just change the scales. Don't switch blades or liners. The Blade and the lock are mated to eachother. Just pop the scales off and switch them, blade swap is more of a euphemism than something people actually do.
bbturbodad wrote: ↑Wed Apr 24, 2019 2:36 pmThat's my thought too... I'll probably swap it over with the new blade.
I have one knife with a groove in the Pivot as well: a Rex 45 Para 3. No idea why.
When I swap blades I always swap stop pin and pivot as well (for example from G10 to Ti Military); and lock for back-locks. Just a thought.
Agree.
- bbturbodad
Yep swapped the scales, pivots, and stop pins...all good!
Oh yeah, I stole the black screws and clip too.
-Turbo
- Forest Green
bbturbodad wrote: ↑Wed Apr 24, 2019 8:10 pm
Wow, great thinking on the match-ups, really makes sense to me!!! I'm not sure which I like more.
Looks good
Should hold lubricant and reduce the contact area a bit which reduces friction with or without lube.
I'm thinking it was a CQI thing.
I see it on my lil native as well.
How old is the 20cv version?
You guys are correct, the groove helps keep lubricant in the pivot.
Stay safe,
Mike
Stay safe,
Mike
- bbturbodad
I think it's from last April.
Thanks!Michael Janich wrote: ↑Thu Apr 25, 2019 6:57 amYou guys are correct, the groove helps keep lubricant in the pivot.
Stay safe,
Mike
-Turbo
Grooved pivots on M4 and REX 45 blades...Rust prevention measure?
Bow River 8Cr13MoV * Zome Dragonfly VG-10 * Para 3 LW BD1N * Para 3 CPM Rex 45
PM 2 Böhler M390 * PM 2 CPM 20CV * PM 2 CTS 204P * PM 2 CTS Maxamet * Yojimbo CPM M4
Shaman Zapp Z-Wear PM * Spydie Chef Zapp LC200N * Techno 2 CTS XHP * Drunken CPM S90V
Benchmade Griptilian 20CV * Mini Grip S30V * Kershaw Launch 1 CPM 154 * Kershaw Link S35VN
Gerber Applegate Fairbairn Covert ATS 34 * KaBar 1211 AISI 1095 * Cold Steel CS-13QMBIX CPM 3V
