Hi All! :)
I was just wondering how many others would be in for a Caly 3.5 Damascus?
I understand it probably hasn't been done due to material cost and various other reasons but I would love one. I favor the Caly 3.5 slightly more than the Caly 3. I would be willing to pay a premium if they made them to make it worthwhile for Spyderco. I love both my Caly 3 Damascus and they are absolutely amazing/smooth (have every Caly 3/3.5). Anyway I'm somehow holding out hope that this may turn in to something that gets noticed so Spyderco could possibly ponder the idea. Thanks for entertaining me! :spyder:
Best
MrSuperBlue
Caly 3.5 Damascus possible?
How about a Caly 3.5 damascus?!
So what's the next Super Blue model coming?
- RadioactiveSpyder
Re: Caly 3.5 Damascus possible?
This version has been requested for years on this forum and in person, with no luck. I’m sure this isn’t the first time this thread has appeared.
- curlyhairedboy
I'm down for any backlock or comp lock in damasteel.
- RadioactiveSpyder
It would not be a Damasteel blade if it’s to be a true 3.5 inch version of the original. The original is VG-10-based Damascus.
Do you know if it was truly layered or the kind of wrap around Damascus that Spyderco uses now??RadioactiveSpyder wrote: ↑Fri Mar 22, 2019 5:16 amIt would not be a Damasteel blade if it’s to be a true 3.5 inch version of the original. The original is VG-10-based Damascus.
--Wovoka
--Wovoka
- bearfacedkiller
I want a 3.5 SS/CF/Damascus to match my 3.
Same goes for the green g10 and HAP40.
I also want both of these configurations in the C54 Calypso.
- jabba359
I'm not exactly sure what you mean by "truly layered" vs. "wrap around," but will give it my best guess. D.P.S. 15 is the type used on the Caly 3/Endura/Delica, which is 15 layers, a VG-10 core, then 15 more layers on the other side. I suppose you could say the Damascus "wraps around" the core cutting steel. The Damasteel Damascus they use on the 40th Anniversary Native is layered all the way through, with the Damascus also comprising the cutting edge.jdw wrote: ↑Fri Mar 22, 2019 5:26 amDo you know if it was truly layered or the kind of wrap around Damascus that Spyderco uses now??RadioactiveSpyder wrote: ↑Fri Mar 22, 2019 5:16 amIt would not be a Damasteel blade if it’s to be a true 3.5 inch version of the original. The original is VG-10-based Damascus.
But in either case, the Damascus is true layers, and not just a fake screen printing on the surface, if that was your concern. RadioactiveSpyder was just pointing out that it wouldn't use Damasteel if history is any indication.
Thank you for the clarification. You nailed it for me.
--Wovoka
--Wovoka
