Which Knife Steels Have the Best Corrosion Resistance
Re: Which Knife Steels Have the Best Corrosion Resistance
My two favorite are corrosion resistance and high sharpness followed by easy sharpening, Looks like I am VG-10 and LC200N.
Your data in a chart, Larrin, hope you don't mind.
- SpyderEdgeForever
Doeswhateveraspidercan wrote: ↑Mon Jan 14, 2019 7:57 pmMy two favorite are corrosion resistance and high sharpness followed by easy sharpening, Looks like I am VG-10 and LC200N.
I like those also.
That looks nice. I only provide emotionless numbers. You shouldn’t call it PREN Acetic though as it is not a pitting resistance. Call it Cr-eq Acetic or something,
The obvious choices that we all have had experience with are H-1 and LC200N. I was told some time back that there is a steel called Cowry X that is supposed to have good corrosion resistant properties.
Also is it safe to assume that nitrogen based steels in general all have good corrosion resistant properties?
Sorry maybe a dumb question here...
But is there a reason they can't completely 100% replace Carbon with Nitrogen? Maybe I'm misunderstanding things but if you could completely remove carbon would you be able to remove any possible pitting from corrosion?
- SpyderEdgeForever
I second this. Larrin and others, what would a steel be like if it had 100 percent carbon removed, and was nitrogen and iron with chromium and others?
Why would 14C28N have better corrosion resistance than BD1N?
Part of the reason is the recommended austenitizing temperatures. 14C28N is higher. BD1N also has higher carbon.
Cowry-X is equivalent to ZDP-189.JD Spydo wrote: ↑Mon Jan 14, 2019 10:01 pmThe obvious choices that we all have had experience with are H-1 and LC200N. I was told some time back that there is a steel called Cowry X that is supposed to have good corrosion resistant properties.
I’m not sure assuming all nitrogen steels have good corrosion resistance is a valid assumption, especially the 0.1% conventionally produced ones. It just so happens that most steels advertised as “nitrogen steels” also have good corrosion resistance.
In the Vanax patent they found that leaving carbon at 0.35% improved properties including corrosion resistance. I think I explained why in the nitrogen steel article I wrote.
I would suggest you the https://swordsswords.com/big-bowie-stai ... knife.htmlDurable and strongly rust-resistant.Larrin wrote: ↑Mon Jan 14, 2019 1:48 pmI generated a simple method for predicting the corrosion resistance of knife steel, and then ranked them all. https://knifesteelnerds.com/2019/01/14/ ... esistance/
How have you made it to 31 posts while sharing spam links?Joseph08 wrote: ↑Wed Jan 16, 2019 5:24 amI would suggest you the https://swordsswords.com/big-bowie-stai ... knife.htmlDurable and strongly rust-resistant.
Wow all that knife for only $16.99 How will Spyderco Ever compete with that? :rolleyes:
