Stripped screw tips?
csx2006
Post by csx2006 »
Just had a new para 2 come in and changing the clip on it. The screws were in SOOO tight I stripped them. Any tips on getting them out?
brainfriction
Re: Stripped screw tips?
Post by brainfriction »
If you have a dremel you can try cutting a slot for a flathead screwdriver... but chances are you won't be able to generate enough torque to break them free if you haven't already.
Tbh, I'd just send it back to Spyderco and have them fix it, they're pretty good at getting out stripped screws.
For future reference, get a nice set of Wiha drivers. T6, T8, and T10, they're the only tools I feel confident using on any of my knives with threadlocker.
Doeswhateveraspidercan
Take small pair of good quality vice grips like the ones on a leather man crunch tool. Get a positive grip and loosen by grabbing the head of the screw try that before slotting.
Or something like this but smaller I would guess
6 piece Easy Out Screw Extractor Set,Damaged Screw Broken Bolt Water Pipe Remover Set By Nizzco https://www.amazon.com/dp/B07B7K5772/re ... eCb48R9SS3
Rhodie
Post by Rhodie »
VMPVT-001-5 Mini - 5" Screw Extraction Pliers. I bought these from Amazon and they work great. Got the recommendation from a fellow on Blade Forums. The design of the jaws make it conducive on gripping very small screw heads such as the type found on folders to include Spyderco.
Rhodie wrote:
Fri Dec 14, 2018 6:25 am
Oh now those are very nice, going to order a pair today. Thanks.
Pelagic
Post by Pelagic »
You may be able to get a VERY small easy out and grind the top flat so that the grooves will be sharp at the end and grab the rounded out torx groove of the screw.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
DBCOOPER
Post by DBCOOPER »
I'd agree with brainfriction, I've had the best luck with using a Dremel and creating a flat head for a screwdriver to screw it out
I came here to cut sh#$ with my knives and chew bubblegum, and I'm all out of bubblegum
brainfriction
DBCOOPER wrote:
Fri Dec 14, 2018 6:21 pm
Yeah, heating them up with a soldering iron first will help break them free too.
gull wing
Post by gull wing »
Heat, Heat, Heat,
1. Soldering Iron, but be careful not to over heat and burn the G10.
2. Boiling water works best (for me) :
Bring water to boil, shut off fire, drop in.
Set 5 min.*
Place knife on towel push down hard with (GOOD) tool and turn.
*If unsuccessful drop back in hot water, wait longer.
:eek: Next time do this first.
SCARAMOUCHE! :bug-red-white
lonerider1013
Post by lonerider1013 »
On one of the metal handle byrd knives my screws were stuck and stripped. I cut a groove with a file and used a flathead to take them out.
They were really stuck. Imagine you could do the same with that knife....
"A fool's blade may be sharper than his brain"
“Learn to ride a bicycle. You will not regret it if you live." - Mark Twain
