Para won't stay sharp
zhyla
Re: Para won't stay sharp
Post by zhyla »
Ric wrote:
Tue Dec 04, 2018 11:29 am
Raise a burr on one side the flip to the other side and raise a burr again.
A cut into some wood to remove some burr and other stuff.
Oof. No offense but I think this is counter-productive advice. Intentionally grinding a burr just unnecessarily stresses/deforms the edge material, leading to easier failure.
Avoid burrs. If your system doesn't support alternating passes then make sure you're using coarse enough abrasives leading up the final passes.
Ric
Post by Ric »
When you create a burr on both sides then you know you are on the apex. Therefore i recommended that.
Ric wrote:
Thu Dec 06, 2018 2:05 pm
You can also use a light source and look for the edge to reflect light. Then you don't have to burr the edge.
