Doeswhateveraspidercan wrote: ↑Thu Nov 01, 2018 1:52 pm
Vivi wrote: ↑Wed Oct 31, 2018 9:38 pm
That's one of the biggest drawbacks of those systems. I couldn't imagine paying $300-500 for a sharpening system that can't even give my knives optimal edge angles.
I'm happier dropping $50-80 on some stones and going at it free hand. I'll take the sloppier, thinner bevels.
I'd imagine most people are happy with them though. Free hand or not I don't see many people running angles like your Millie and my users.
Would you mind sharing the stones you are using, for only 50 - 80 dollars it is worth a try. I have lately been considering free hand after seeing the results of this knife at these low angles.
Sure.
6" DMT Extra Course (the one with holes), and a 6" DMT fine.
The DMT Fine was the first sharpening stone I ever bought for myself. I had a few hand me down arkansas stones and a few kitchen style rods before that, but wanted to see what all the diamond hype was about.
I paid $30 for it. I used it for everything. Did my first reprofiling jobs with it, polished edges on it, and of course used it for regular sharpenings.
As I learned more about sharpening I realized a lower grit stone would dramatically speed up reprofiling, so I got one of the cheapest DMT's I could find, the 6" XC for $35.
I reprofiled over 100 knives on that DMT. Including many like the pictured Pacific Salt where I essentially converted a saber grind into a scandi grind.
Both of those stones have over a decade of wear on them and still work great.
Eventually I replaced each with more expensive stones. The XC DMT was replaced by a longer, XX coarse continuous surface stone. The holes don't provide any benefit IMO and can actually cause the tip to get caught up if you're not careful. The short length made it easy to slip off the edge of the stone while reprofiling and scratch the tip.
The DMT fine was replaced by a Spyderco Medium bench stone, which is what I pretty much exclusively use to sharpen all of my knives. It's also a longer stone, and it removes metal more slowly. To this day I love the edge I get off that DMT fine, but it removes metal too fast to be my daily touch-up stone. The Spyderco stone works much slower, but not as slow as their fine.
I typically go straight from the XX course DMT to adding a more polished microbevel. On some knives, particularly carbon steel knives, I still use the DMT fine to polish the bevel before I add amicrobevel on the Spyderco stone.
That DMT combo would easily last another decade based on my experiences with them. It's all I need to take a dull knife with an obtuse edge down to 10 degrees per side with a hair splitting sharp microbevel.
