Is there a viable replacement option for Teflon washers used in Spyderco knives? Eric talked on YouTube via Blade 2018 that Spyderco has been evolving in regards to washers. That Spyderco has learned a lot in a short time and is using bronze phosphorus washers now.
I am not sure how Spyderco will deal with a Teflon washer failure, but is there aftermarket bronze phosphorus washers that can be used if the knife owner chose to do so?
Spyderco Teflon washer replacement?
- The Deacon
Re: Spyderco Teflon washer replacement?
You can purchase phosphor bronze washers from pretty much any knife maker's supply company.
You might try USAknifemakers.com :)
Has anyone done this before? Like the mantra 1 (thin metal washer) and the Lionspy (Teflon washers) ???
