Anyone able to help with this clip?
Re: Anyone able to help with this clip?
I would suggest taking it off the knife and adjusting it to your preferred tension. It would take some trial and error though.
You could try removing the clip and slightly bending it to ease the tension.
- Nick
I have/had the same issue with my Firefly. I slight bend does help but the clip is so small that you have to get it just right to make it work ok.
- farnorthdan
Like others have already said, remove and tweak it to your liking. You could also contact someone who does custom work and have them fab something up for you.
You may try folding up a piece of paper and wedging it under the clip for a few days if you don't feel like removing the clip. That may be enough to loosen it up enough.
Remove the clip. Wrap the end that attaches to the knife in a cloth and clamp in a pair of pliers. Then bend the clip outward to make it a little looser. You will likely have to put it back on the knife several times and continue to tweak it. If you bend it too far just bend it back the other way. I do this with all my clips to get the desired tension.
I have a similar problem with most of my knives - regardless of brand. I wear heavy Duluth work pants, and I have not had a single clip fit out of the box. What I've found is that if I put the knife in my pocket, with the clip opening against the heavy material, and push while prying the clip open with my thumbnail, I can get the knife to clip on. I do this for a week or two, and then the clip fits just fine. This way, I don't have to worry about taking the clip off (and the potential for me slipping and scratching something as I do) to do the re-fitting.
Just a thought.
Just a thought.
