Stabbing a tire
- jackknifeh
Stabbing a tire
Has anyone ever stabbed a fully inflated tire with a folding knife? I was just watching a movie where someone had stabbed a tire to keep the bad guys from following him and it got me thinking about it. I don’t think a Gayle Bradley, Military, Manix2 or any of those guys would have a problem but I’ve never done it. Normally I have the Sage 1 on me. I have no reason to think it would fail but the liners on that knife aren't the thickest in the world. I also have no reason to think I’ll ever need to stab someone’s tire but that need would present itself way before I would ever need to stab the hood or door. I think I’m covered either way because I do have a Ladybug on order. :) I also thought the shape of the blade might play a big part. If there is a lot of curve in the spine like a warncliff that may make the blade want to fold closed. A shape where the edge curves up to a straight spine I think would puncture better. Any thoughts or better yet, experience?
Jack
Jack
I'm a FF and we're taught to flatten a tire for stabilization when needed on auto accidents. This does a few things, it lessens the chance of rolling forward or backward, and puts the car on the ground/or closer to it. When using extrication equipment and chocks are used, flattening tires really does help get a firmer platform. Tanto blades work great, any with a narrow tip work though. I do always think of lock up prior to my stab, as well as a good grasp on the knife.
- The Deacon
Only time I ever flattened tires, I did it by removing the valve stems.
- chuck_roxas45
I flattened a few tires and sidewalls are pretty **** soft. Don't stab. Just press the tip in with the knife angled a bit upward and with a downward pressure so the load is on the stop pin, not on the lock. You can do it with a slippie if you're careful.
- tonydahose
we were drilling on a car awhile back. as mentioned above you want to get the tires flat to stabilize the car. the insructor told us to just pull the valve stems, stabbing would take too long and you might get hurt if you didnt get it thru the tire or losing control of the knife if it did make it thru. i went on the other side of the car and cut into the sidewall with the jumpmaster. it made a pretty loud pop and cut easily into the tire.
WTC #1444 Always Remember
My knives
Spydie count: a few:D
My knives
- Dr. Snubnose
While working as a Bail Enforcement Agent we did a lot of tires...I used a Hypodermic Fluted Ice Pick, with a hole through the handle to let the air out...also empties gas cans, bladders and anything else that needs a quick emptying....All we used to do was push in with force and walla...Doc :D
- SolidState
I know ice fishermen with those.DCDesigns wrote:Hypodermic Fluted Ice Pick... Ive never heard of anything that sounds more like a murder weapon, hahahahh! doc where the **** did you get that?
"Nothing is so fatal to the progress of the human mind as to suppose that our views of science are ultimate; that there are no mysteries in nature; that our triumphs are complete, and that there are no new worlds to conquer."
Sir Humphry Davy
Sir Humphry Davy
- Dr. Snubnose
Mine is made from Titanium, they were used during Desert Storm , to dig for landminesDCDesigns wrote:Hypodermic Fluted Ice Pick... Ive never heard of anything that sounds more like a murder weapon, hahahahh! doc where the **** did you get that?
[img][IMG]http://i991.photobucket.com/albums/af33 ... 7_1559.jpg[/img][/IMG]
- jackknifeh
Dr. Snubnose wrote:While working as a Bail Enforcement Agent we did a lot of tires...I used a Hypodermic Fluted Ice Pick, with a hole through the handle to let the air out...also empties gas cans, bladders and anything else that needs a quick emptying....All we used to do was push in with force and walla...Doc :D
Murder weapon sounds about right. How would you empty someone's bladder without murdering him/her? :eek:DCDesigns wrote:Hypodermic Fluted Ice Pick... Ive never heard of anything that sounds more like a murder weapon, hahahahh! doc where the **** did you get that?
Jack
- jackknifeh
- psychophipps
I had a situation where there was a large van parked for over two months straight in a very unsafe location for other drivers coming in and out of my apartment complex. Police couldn't do anything as it seemed drivable so I asked all of my fellow tenants if it was their van before I "took care of the potential mobility problem". Not sure what tires you guys have been poking holes into, but my experience as a 6' 2" anf 200-plus pound guy with some knife training in a point-driven methodology was far from "like a knife through butter" when I went at the sidewall.
Like others have mentioned, there is zero need to stab. I've found the best spot to puncture is just outside the tread, about where the lettering is on the sidewall. Put your tip against the tire, angle it downward, and put a little weight on it. I've seen an Endura, Sebenza, Emerson Commander, and Griptilian all go through with no issue.
Stabbing a new tire is not that hard, it is the real old ones that have been backed hard by the sun....those are the hard ones. Any good knife with a sharp point should be able to do it easily, the problem is that when you stab an inflated tire the amount of air that rushes out can be well....surprising and smelly! Cut the valve stem. Less surprises that way.
- dcmartin2001
