Ice handles?
- Nifty_Nives
Ice handles?
hey guys, on one of those "make a spydie" models, would it be possible to make a mould for, and then freeze a....
ICE HANDLE! it would be a pretty cool idea, and it would be more of a silly gag.
how could you do this, (i know its not practical) but we should carve out something, and be like "oh look at the 2010 forum knife son!"
i was thinking... we use a mule, make a mould, add some glow powder, and pour our water and freeze, then we etch out, and paint the inside letters of "spyderco forums 2010"
Andy
- spoonrobot
- Nifty_Nives
You must be an Andy Goldsworthy fan. I am too.
If you wanted to have a better shot at this, I would recommend using a pykrete mixture (water mixed with sawdust, then frozen => http://en.wikipedia.org/wiki/Pykrete ). It's much stronger than pure ice, and it takes a lot longer to melt, so you have a better chance of getting the scales done and attached before they turn soggy. Either that, or do this work outside, during winter, someplace where it snows.
Good idea Nifty,Nifty_Nives wrote:hey guys, on one of those "make a spydie" models, would it be possible to make a mould for, and then freeze a....
Chemical ice.
http://www.acehardware.com/product/inde ... =109384216
http://en.wikipedia.org/wiki/Polyester_resin
Bondo, liquid and cloth polyester, forms a good handle for a knife. Your creativity can run wild. Wrap, soak and repeat. Sand to your satisfaction.
This terrific knife, made by the talented, gifted and generous yam350 in about 4 hours (includes blade cutting and finishing), is made from polyester cloth and resin:
oregon
- Clawhammer
I have always wanted a set of plexiglass scales for my mule. What better way to show off the the form of a mule than water clear scales? Water clear epoxy would (pun intended) seal the deal.
Plexiglass is a bitach to work with. It starts to melt with almost any machining. I've done a little bit of freehand work with plexiglass and it wants to melt when it is drilled or sanded. Plexiglass may not be a good working handle but it would be so cool to show off. How about some well checkered plexiglass scales?
Mules are should be working test knives but I want one to show off.
This post was not meant as a hijack but is so silly as to open itself to a variety of ideas.
Not really all that slick
Of course you want clear scales and you deserve to have them as well.
There is a long rich history of clear scales on salesman sample cutlery. Some collect it.
I have your ice scales right here, crystal clear are cut small by vendor, flourescent blue clear is still in the 12" square, 1/4" thick, sheet.
http://www.delviesplastics.com/mm5/merc ... _Size_Page
I've seen ice this color while inside the, now long gone, huge and extensive ice caves on Paradise Glacier on Mt. Rainier (I put a light on the far end of the clear flourescent blue sheet and the color transferred to the small clear scales):
The protective brown paper stays on until the scales are finished or destroyed trying to finish.
oregon
oregon
- Clawhammer
- defenestrate
