Has anyone added a clip to a ladybug?
Blue72
Post by Blue72 »
I am trying to get some ideas to add a single wire clip to my ladybug.
Has anyone added a clip?, I would like to get some idea's.
Thanks
Post by The Deacon »
Adding a clip has been done, either on a Ladybug, or a Jester which used the same handle the current Ladybug III uses. However, the clip was flat metal, not wire. It was mounted using a single screw through the lanyard hole.
Blue72
Post by Blue72 »
What was used to keep the clip from rotating?
Domanfp
Post by Domanfp »
I asked str about doing it a while back and he said it would be possible but you would have to be carefull with the unlined frn
-Frank
Delica and Endura are great knives! They're the low priced crack samples that'll get you hooked on spyderco! Feed the need!
-Michael Cook
yablanowitz
Post by yablanowitz »
In my case, blind luck and torque. ;)
monsterdog
Post by monsterdog »
yablanowitz wrote:In my case, blind luck and torque. ;)
I find the waving much more impressive :o Does it (the wave) actually work on such a light/small knife?
yablanowitz
It does if you carry it clipped and pull vigorously. It doesn't open all the way 100% of the time, but it at least opens far enough for me to reach the Spyderhole with my thumb.
RIOT
Post by RIOT »
The Deacon wrote:Adding a clip has been done, either on a Ladybug, or a Jester which used the same handle the current Ladybug III uses. However, the clip was flat metal, not wire. It was mounted using a single screw through the lanyard hole.
any pics of that around ?
spoke too soon they are above my post
amen74
Post by amen74 »
Very interesting knives you've got there Yab. All look as functional as can be.
Aaron
Current EDCs: Golden models
:spyder: FG D2 Military:cool: Orange UKPK:spyder:
NEXT: Rock Lobster, Manix2, TiMil
Jay_Ev
Post by Jay_Ev »
Looking very closely, I think I can see the faint etching of the word "Pilot". Is that clip from a ball-point pen?
yablanowitz
Yes, part of it is. I took the clip off an old pen, soldered it to a screw, ran the screw through the lanyard hole and put a nut on the other side. It's ugly, but it works, which pretty much sums up most of my projects. ;)
Domanfp
Post by Domanfp »
does solder really hold that well?
-Frank
-Michael Cook
yablanowitz
Silver solder certainly does. You just have to be sure that the clip can take that much heat. Even lead-free plumbing solder is pretty strong if you get a good joint.
DMgangl
Post by DMgangl »
I did it a while back to a Finch. I got the idea from here a few months back. The lanyard hole on the Finch is about perfect for a 4mm bolt. The Ladybug lanyard hole is a little bigger I had to tap it with a 5mm. This is the only pic I got.
DM
Smile, it can always get worse
RJNC
Post by RJNC »
There's a great concept pic Dialex made that has a concept Ladybug "Gentlebug" with a clip.
