Mule Team Tutorial
Mule Team Tutorial
During the summer I put a handle on a friend's Mule Team blade and took some pictures to document the process. With the release of the second run of Mule Team blades in M4 I thought you might like to see them. Apologies to anyone who has seen them already over on British Blades.
First a picture of the raw materials, a Mule blade in 52100 steel and some Desert Ironwood.
This pic shows that the scales need to be flattened.
To do this I have secured some 40 grit paper to a piece of laminate flooring. The laminate is useful stuff as it is flat.
Once the scales are flat I changed to a finer grit...
and checked them by holding them up to the light. There is a slight gap at one corner but I'm not going to use this part of the scales.
The next step is to use double sided tape to hold the two scales together. This means I can treat the two scales as one block.
and mark out the rough outline of the handle. I spent a bit of time looking at the figure in the wood to make sure I get the best out of the block.
There a lots of different holes in the blade for different pin configurations. we're going to use to 6mm brass pins and a 6mm brass lanyard hole.
Now to rough out the outline of the handle with a coping saw.
Post 2
I like to leave plenty of wood on at this stage
At this point i'm going to work on the edge of the scales that will be next to the ricasso of the knife. Its difficult to work this part of the scale once its glued to the blade so I need to get it done now.
First use a rasp to get down to the line...
Then use the pillar drill with a drum sander to tidy up.
Now it looks like this...
A few minutes on the buffer
and it looks even better
I'm using brass rod and tube from the DIY store, it needs cutting to length...
I drilled a test hole in some oak to check the fit
Centre punch the lanyard hole
Drill
Drill
Check the position of the other holes
drill the other two holes for the pins
OK, we're just about ready to glue it all up. First I've got to separate the scales. I'm using my trusty Victorinox pairing knife! I've also roughed up the Mule Team handle, taking care to keep the scratches away from the ricasso area.
Everything is to hand, ready for the epoxy. I'm using 24 hour Araldite. I've wiped all of the pieces over with some meths and have given them all plenty of time to dry.
Make sure the scales are well covered
With one scale in place I make sure the holes in the Mule Team handle are all filled with epoxy
Then it all gets pressed up tight in the vice
After half an hour I clean up the top edge of the scales next to the ricasso. wipe away any excess epoxy.
I'll leave it overnight before I do any more work but I'll keep checking the top edge of the scales and wipe away any more epoxy that appears.
Here are the next series of photographs.....
A pic of the blocks I'd used to clamp up the scales. Note the holes where the pins are, this makes sure the pressure from the clamps is applied to the scales, not the pins.
The glue line looks good
The first job is to use a rasp to get rid of some of the excess wood...
Once I've got down to the metal I tidy things up on the drum sander
And then its a case of filing, sanding, filing, sanding until things take shape.
Once I'm happy with the basic shape I use the buffer to show up the scratches and work between the buffer and some 240 grit paper
The next step is to apply a few coates of Danish oil.
Clean out the lanyard hole
And now the knife is looking like this
I'll give it a good look over for any scratches or parts that I'm not happy with and then go back to applying Danish oil.
- quattrokid73
Wow!
I was planning on going through the same process for my Mule when it comes. This was perfect timing and such a thorough guide.
Thanks a million!
Now who's making a kydex sheath any time soon and wants to post a demo?
:D
Thanks a million!
:D
http://www.coroflot.com/aham73
:spyder: Orange Millie, UKPK Orange, DP UKPK, FRN UKPK Maroon DP, Urban Wharnie, Chokwe, Zulu, Mini Persian G-10, Spin Etched, Leafstorm, Caly Jr Gray, Sage 3, Lum CF
Every machine is the spiritualization of an organism.
- Fred Sanford
That is very very nice. That is just beautiful.
I love the fact that you use a coping saw and rasps. I like doing things all by hand rather than using electric stuff.
Thanks for taking the time to post. I think I will actually be getting a Mule Team knife this time around and I will want to follow this to make my handles.
Good job man. Very pretty.
- Fred Sanford
- tonydahose
very nice write up!
WTC #1444 Always Remember
My knives
Spydie count: a few:D
My knives
- Mr.Sparkitle
Mr.Sparkitle wrote:^ I would also like to know where you got the lanyard tubing. Also great write up and your work is very nice, wish my mule came out half that nice.
The brass pins and lanyard tubing came from B&Q, a national chain of DIY stores in the UK. I'm sure you could pick up a length in most decent hardware stores.
Nick
