Just to be clear: I did not say that. But just that in my personal use and to my own big surprise ffg SE so far works better in most and not worse in any task that I performed than PE. I also literally said that there certainly WILL be tasks where PE works better, just not (so far at least) in my personal use (viewtopic.php?p=1442809#p1442681)jpm2 wrote: ↑Thu Aug 13, 2020 5:44 amI've experimented processing squirrel and deer with se and the 2 real negatives I remember aside from more ragged cuts and requiring more force, were getting excess hair in the meat during skinning, and catching bone all the time.Wartstein wrote: ↑Wed Aug 12, 2020 10:53 pmI don´t know nothing about being a professional butcher, but personally prefer SE when cutting meat.
I could imagine that beside having to make very clean and nice looking cuts (as David mentioned) another reason for butchers using PE might be, that they frequently and very quickly have to touch up the edge (with a honing steel I guess). This could work better with PE than with SE. Or maybe not "better" but "faster".
I'm just confused at some comments saying se is at least as good as pe for everything, when there's some things impossible for it to do, like complete a push cut against a flat surface for instance.
Give The Spyderedge A Chance Thread
Re: Give The Spyderedge A Chance Thread
Like push cutting against a cutting board? Definitely not impossible when it can push cut receipt paper or whittle hairs...
- Shannon
MNOSD 0006
MNOSD 0006
- MichaelScott
What?
Personally, when all is said and done, I have not encountered any cutting task my PE knives cannot do that a SE could. Besides, the most important aspect for me is I don’t like how SE blades look.
http://acehotel.blog
Team Innovation
Team Innovation
- VooDooChild
You can cut anything with anything if you have enough force.MichaelScott wrote:What?
Its just about which edge types are better at certain types of cuts. By their nature, a plain edge is going to be better at push cuts, and a serrated edge is going to act more aggressively in a sawing motion. I always like to think of a serrated edge as somewhere in between a plain edge and a saw.
Look up Cliffstamps review of the atlantic salt. He cut through the tread of a tire. None of the plain edge blades made it through the steel belts in the tread. The serrated edge did, as would a saw.
- legOFwhat?
Maybe since it's a "test mule" testing SE versus PE would be quite a fun thing to do :) As far as particular blade steel the new SPY27 would be interesting and since there are some PD#1 left I wonder how well that would perform with teeth(?)JD Spydo wrote: ↑Wed Aug 12, 2020 8:38 pmIs there any particular blade steel you would like to do that with? I would like that too>>> However I would like it even more if they did an outdoor Salt Series Sprint Run of the TEMPERANCE 1 model both in LC200N in SE & PE along with really good updated sheaths. The TEMP 1 in SE is a salt water crocodile of a knife :cool:
I've loved the shape of the Temp1 and 2 since I 1st layed eyes on them. Wish they didn't command so much $ on the 2nd had market...A salt Sprint would be instant buy in that shape!
-Larry
MNOSD #0049
MNOSD #0049
SE knives can push cut against a flat surface... that’s all I was saying.MichaelScott wrote: ↑Thu Aug 13, 2020 7:49 amWhat?
It’s all personal preference, for me, they’re actually easier to sharpen and I love the performance.
- Shannon
MNOSD 0006
MNOSD 0006
Totally fine of course if you don´t like SE and prefer PE, no matter what the reasons might be (and if it´s just the looks!) :)MichaelScott wrote: ↑Thu Aug 13, 2020 7:49 amWhat?
But: If your first sentence defined on what level of depth we´re discussing on this forum: That would actually end most discussions, proposals and conversations... I mean, then it would be like: "Why a PM2, since there is no cutting tasks a Delica generally can´t do"? "Why REX 45, since there is no task VG10 can´t do"? and so on...
But here people who actually have experienced Spydercos SE came to really value it and in many cases over PE (and that does not mean PE is "bad" of course"!) - and consequently are wishing for more SE.
I still don´t know what YOUR personal, extensive experiences with Spydercos SE in ffg are - but should it be that you actually never really compared it to PE in real use, it is a bit like if someone would say "Never tried a Manix myself, but I feel it is redundant and I don´t see why people like it, since I DO have a PM2 and it works perfectly well..."
My thought also.MichaelScott wrote: ↑Thu Aug 13, 2020 7:49 amWhat?
Only if you turn the material over and use 2 cuts, but that's not always an option, and I think you knew what I was talking about.
You said push cutting against a flat surface.... is that not like cutting something on a table or cutting board? Do elaborate....I could see how laying a zip tie flat and popping it into pieces may be difficult, but who cuts zip ties up like that?jpm2 wrote: ↑Thu Aug 13, 2020 9:45 amMy thought also.MichaelScott wrote: ↑Thu Aug 13, 2020 7:49 amWhat?Only if you turn the material over and use 2 cuts, but that's not always an option, and I think you knew what I was talking about.
- Shannon
MNOSD 0006
MNOSD 0006
^I think you guys are arguing over meaningless details. I can cut anything on a cutting board with a serrated knife without repositioning the material. What does it matter whether or not it is a "true push cut" with absolutely zero horizontal motion? Is that something that has any relevance whatsoever in any realistic cutting task? I think not.
- Connor
Yup. I’m curious to know what they mean. I edited to add the zip tie example... other than a test it’s null in real world use.The Meat man wrote: ↑Thu Aug 13, 2020 10:06 am^I think you guys are arguing over meaningless details. I can cut anything on a cutting board with a serrated knife without repositioning the material. What does it matter whether or not it is a "true push cut" with absolutely zero horizontal motion? Is that something that has any relevance whatsoever in any realistic cutting task? I think not.
- Shannon
MNOSD 0006
MNOSD 0006
- xceptnl
Well said.The Meat man wrote: ↑Thu Aug 13, 2020 10:06 am^I think you guys are arguing over meaningless details. I can cut anything on a cutting board with a serrated knife without repositioning the material. What does it matter whether or not it is a "true push cut" with absolutely zero horizontal motion? Is that something that has any relevance whatsoever in any realistic cutting task? I think not.
this is actually why i love the way spyderco does serrated blades. apart from spyderedge being vastly superior to any other serration patterns, i love that de spydies leave a bit of plain edge toward the tip. that's more than enough to push cut a zip tie if that's how you like to do it. it's more than enough to do finer cuts of thin plastic packaging or paper. it's perfect.
There's no telling how many hundreds of zip ties I've cut against a flat surface when that was the only option. You run into it all the time in an industrial setting. I guess if you haven't done it, or needed to do it, it just doesn't exist as a "realistic cutting task" ?
I've given the spyderedge a fair chance by attempting all the tasks I use a pe for, and only found a very few that it's as good or better at.
I guess there's no need to list anymore unrealistic cutting tasks the spyderedge can't do, or is horrible at, so I'm out.
This is why I like to have a little PE at the tip. It's also a cut that in 3 years I honestly haven't had to do so some people's routines may just differ. For pretty much everything else I've seen SE to outperform PE.
Having not read the thread, only the title, I promise I will give a folder in full SE a chance as soon as it comes on the Spydiechef. I will be a day one buyer.
Interesting... To be honest I never really paid attention but I don’t think that’s anything I encounter on a regular basis or I grab something different from my tool box cuz it’s right in front of me (I’m an automotive technician).jpm2 wrote: ↑Thu Aug 13, 2020 10:44 amThere's no telling how many hundreds of zip ties I've cut against a flat surface when that was the only option. You run into it all the time in an industrial setting. I guess if you haven't done it, or needed to do it, it just doesn't exist as a "realistic cutting task" ?
I didn’t mean to be offensive in any way... I was only looking for a more in depth explanation of what kind of cuts you were talking about and clearly I misunderstood as others seem to have followed. My apologies.
- Shannon
MNOSD 0006
MNOSD 0006
Fair enough. I guess it's not something I have ever been unable to tackle with SE but I see what you're saying. No offense meant, jpm2.jpm2 wrote: ↑Thu Aug 13, 2020 10:44 amThere's no telling how many hundreds of zip ties I've cut against a flat surface when that was the only option. You run into it all the time in an industrial setting. I guess if you haven't done it, or needed to do it, it just doesn't exist as a "realistic cutting task" ?
For the record, I do like and use PE as well as SE. To paraphrase a well-known saying, they're both good, just different.
- Connor
I couldn't agree with you more. Because the one Spyderedged folder I use for some of the most brutal jobs in my 440V, Golden, Co made NATIVE model. It has about 3/8ths to 1/2 inch PE tip on it and it sure comes in handy on occasions. And I can't begin to tell you all how many really mean cutting jobs I've done with that folder. And the extra PE tip really has helped in several jobs over the years.
Also I'm getting to the point to where I've decided that I could more easily get along with one Spyderedged folder a lot better than I could if I were marooned somewhere with one plain edged folder. You can just do far more rough jobs with a SE than you can do with a PE blade. Not to mention you don't need to sharpen a serrated blade nearly as often as you do a plain edged.
i actually had to perform this kind of cut once in the last few years. there was something zip tied to my kid's new bike and it was tightened all the way down so you couldn't get under it to cut it at all. of course i reached for my se pac salt and used the plain edge at the tip to push through. being that i was push cutting through hard plastic and into a piece of metal on the other side, i would have never used a knife with a more brittle steel, to include s30v. the h1 was perfect for the task.
