Weird lines on blade
Re: Weird lines on blade
Is it possible that you may have forgotten that either 1) you used your blade to swipe a spider web out of your way or *EDITED - Inappropriate - TazKristi*
The coin doesn't really scratch the blade so much as coin rubs off onto the blade. The effect looks the same. If that's what happened some Fitz might clean it off.kobold wrote: ↑Mon Sep 13, 2021 3:22 pm
But how can some coin scratch a 62 HRC XHP blade on a Chap?
Notsurewhy wrote: ↑Wed Sep 15, 2021 4:54 amThe coin doesn't really scratch the blade so much as coin rubs off onto the blade. The effect looks the same. If that's what happened some Fitz might clean it off.kobold wrote: ↑Mon Sep 13, 2021 3:22 pm
So it is the same deal like usually with DLC? All's well that ends well.
... I can't see any Image here that'd show the scratches..?
- Buddafucco
The post was edited and the pic was removed. It definitely was there though.
•• Beau
Without being able to see the picture, I'm going to go out on a limb and say that OP is actually Gargamel and this was caused by the Smurfs he was trying to capture.
Serves him right!
Serves him right!
-Thomas Jefferson
-Thomas Jefferson
So you did not find the cause?
Did you ever sharpen it on a Worksharp Knife and Tool Sharpener (belt version) or similar. If you don't put tape on the blade, the residue of grit on the guides will mark it up exactly like the picture shows/showed.
