What color is the sun on your planet, or are there more than one?
Only 1 sun on my planet, but Superheated water is liquid water under pressure at temperatures between the usual boiling point, 100 °C (212 °F) and the critical temperature, 374 °C (705 °F). It is also known as "subcritical water" or "pressurized hot water."
It’s called a crock pot
So when you super heat water under pressure, what happens when you release it back to atmospheric pressure at those temps?
Perhaps you mean pressure cooker?
Adam
I used a hair dryer last night and pliers on a clip screw. Worked great. Should have hit it with the hair dryer before but that's the first time I stripped a screw head on a clip. It only took one try too. The torx bit just shredded it
Are you gonna cook the knife in a crock pot?
A pressure cooker only boils water at about 250 degrees. It would take A LOT of pressure to boil water at 500 degrees.
If you release super heated water under pressure to atmospheric pressure it will boil extremely rapidly. I cook beans in a pressure cooker. When I cook beans I always remove the heat and allow it to depressurize slowly. If I just open the vent it boils so rapidly that the beans fall apart. That is good for split pea soup where you just want them pureed. It is not so good for making black beans and rice.
SpyderEdgeForever wrote:
Also, do you think a kangaroo would eat a bowl of spagetti with sauce if someone offered it to them?
The point is you can't have 500 degree water at atmospheric pressure so that you can then dip a knife into it. Even if a pressure cooker could get it that hot, as you said the instant you pop it open it'll essentially explode and/or immediately turn to water vapor so you can't simply dip your knife in it and hope it breaks the locktite free.
Yea I meant pressure cooker. I’ve got a digital pressure cooker. After it heats up, it’s screen says 290f - 310f. I dunno honestly why this thread lock is such a big deal. I wouldn’t boil my knife for any reason. I’d just get the right bit, and tap it with a rubber mallet real good. And slowly apply torque loosening it. Done deal.
So i picked up a used Pac Salt, (maybe 4th times a charm) and the pivot screw is just spinning when trying to take it out. I thought the female piece had a flat spot it in so that it couldn't just spin but that's what seems to be happening. Red loctite maybe? This one has the older more squared off clip. First knife I've ever had this issue with. Any help would be appreciated. Already tried heating up metal and touching it to the screw to no avail. WOn't come out and just spins.
With my background working on farms and in garages along with gunsmithing and driving 18 wheelers I have run into my share of stuck and tight fasteners. I found penetrating oils, butane powered soldering pencils and blow torches on larger applications along with a impact driver and hammer work wonders. Impact drivers are handy because it allows you combine heat and shock to loosen fasteners. If you don't know you hit the back of the impact driver so it shocks it while turning the fastener at the same time. You can find smaller ones on amazon that will take the high quality torq bits. This method works wonders on scope rings and mounts after red loctite is used.
I have no clue why Spyderco didn't use this orange threadlocker instead of red threadlocker. This replaced my blue and red threadlocker for the most part. It has the strength of the red but can be removed like the blue.
Soldering iron (harbor freight sells cheap ones for $4.99, heats up past 700 degrees). Wait about 2-3 min for it to heat up then hold it onto the stubborn screws for about 45 seconds. The screws will turn no problem.
I’ve dealt with Spyderco red loctite for years and on just about every scale type (g10, FRN, titanium, CF, etc) it’s exactly the same procedure with the same result every time. Never had any damage or failure. Can’t recommend it enough.
The fastener does have a flat on it. The FRN handle had a matching flat before someone started turning the screw. Placing the knife on a piece of leather like an old belt and pressing down hard while turning the screw with a properly fitting driver might help.
They actually listened to their customers and made a change in the process. This is an example of Spyderco’s CQI. At no point do I see a need for a public apology.
Hair dryer works fine, I’ve taken apart a BHQ M4 Military using that method. Same CQI, same red loctite.
Considering I had screws fall out of my never-disassembled CF/S90V Para2 made before they switched to the stronger threadlocker, I hardly think an apology is called for either. CQI, correcting a real, existing issue, is not something to apologize for. That their fix interfered with people doing what the maker advised them not to isn't very apology-worthy either.
