Triangle rods a little wet. Can I use them?
After cleaning them
Re: Triangle rods a little wet. Can I use them?
SM ceramic rods. Do they have to dry completely?
When I clean mine I just clean them with Bar Keeper's Friend and hot water, wipe them off with a paper towel, and maybe let them air dry for a few minutes.
- ChrisinHove
IIRC Cliff Stamp argued that they *should* be used wetted.
Thanks guys. I used Bar keeper's Friend today. It's awesome.
They can be used wet or dry, no harm going either route. Used wet they bits of steel you grind off the knife won't build up on the stone quite as fast.
