Stuck pivot screw PM2
I recently purchased a PM2 in M4 from knifeworks. From what I’ve read the PM 2 is a barrel pivot. I should be able to make adjustments to both sides of the pivot. However; the pivot screw that was under where the pocket clip was can not be adjusted. It won’t budge a mm. Should I not fiddle with it? Am I not supposed to be able to adjust it? Any help would be appreciated. Tried emailing Spyderco but no answer yet.
Re: Stuck pivot screw PM2
Probably best to put this question in GENERAL DISCUSSION.
It is in Spyderco Counterfeits, Clones, Replicas and not as many would visit.
It does take a bit of torque to break them free. I usually just tighten the pocket clip side pivot all the way, then tighten the other side as needed to adjust the centering and action.
