Which Knife Steels Have the Best Corrosion Resistance
Larrin
Post by Larrin »
I generated a simple method for predicting the corrosion resistance of knife steel, and then ranked them all. https://knifesteelnerds.com/2019/01/14/ ... esistance/
steeljustice
Re: Which Knife Steels Have the Best Corrosion Resistance
Post by steeljustice »
LC200N would be a great choice.
Sjucaveman
Post by Sjucaveman »
Awesome, thanks for your hard work.
Adam
Larrin
Post by Larrin »
LC200N is the same as Cronidur 30
Doeswhateveraspidercan
Based on the ones I own and use allot from greatest to least corrosion in this order based upon real use and observation.
H1 / LC200N Cant get either to rust although I think something rusted on top of my H1 as there are rust marks in the same area on both side of the blade in the same area like it was left trapped inside something will have to flitz it tonight and see.
S110V
S90V
CTS-204P / M390
M390
S35VN
Elmax
VG-10
S30V
Tdog
Post by Tdog »
Another great article. I long ago opted out from carrying ZDP-189 around saltwater. While classified as stainless, I found it rusts and pits much quicker than most other "stainless" steels. Your explanation helps to better understand why. Though the list confirms many of my experiences, I'll definitely keep this for future reference. While other factors affect steel and knife choice, this is an excellent guide to stainless qualities. Thanks for your time, effort, and expense in helping us to better understand steel qualities.
Apologies did not realize you took the time to make such a nice article. Interesting to see where things landed.
ferider
Post by ferider »
Thanks for the great article, Larrin.
I have a question: how do your PREN approximations ....
- Acetic acid = Cr + 0.45(Mo + 0.5W)
- Aqua-Regia = Cr + 0.79(Mo + 0.5W)
- Pitting potential = Cr + 2.6(Mo+0.5W)
... work for steels with very high Tungsten content ? For example, CPM Rex 45 with 6.25% W, or Maxamet with 13% ? We haven't seen a lot of corrosion on knives in those two steels in practice (yet), and I was wondering if Tungsten was to take credit for this.
Thanks,
Roland.
The Meat man
Post by The Meat man »
Thanks Larrin, great article!
- Connor
steeljustice
LC200N C 0.38 Cr 15.08 Mo .95 N .50 Mn 1.00
Cronidur30 C 0.25 to 0.35 Mn 1.00 Si 1.00 Cr 14.0 to 16.0 Mo 0.85 to 01.10 Ni .50 N 0.30 to 0.50
Bloke
Post by Bloke »
As always, many thanks Larrin. :)
Larrin
Post by Larrin »
ferider wrote:
Mon Jan 14, 2019 3:02 pm
Thanks,
Roland.
Maxamet is in the table. Rex45 is not but it is a Mo-W steel just like M2 and M4 (plus cobalt) so calculations would probably be similar to those two.
Larrin
Post by Larrin »
steeljustice wrote:
Mon Jan 14, 2019 3:26 pm
I believe you meant to put 0.30C and 15.0Cr unless you have a different composition than the datasheet that you are referencing.
ferider
Post by ferider »
Larrin wrote:
Mon Jan 14, 2019 4:33 pm
Thanks,
Roland.
Don't mean to argue, Larrin, have wondered about these PREN indicators before ..... The Maxamet W contents in the table is not what I see on Carpenter's website (https://www.cartech.com/en/product-solu ... amet-alloy). Per Carpenter, it has 13% W, and - for example - the Pitting potential PREN should be 21.3, higher than any other entry in the table. What am I missing ? Thanks.
Larrin
Post by Larrin »
ferider wrote:
Mon Jan 14, 2019 4:53 pm
Most of the values in the table do not match the bulk composition, as it is a calculation of alloy in solution after heat treatment.
ferider
Post by ferider »
I see. Thanks !
Demon85z
Post by Demon85z »
This is awesome! Very nice work! Thank you.
:bug-red-white I collect them all, and use them all! I use the excuse, "I'm trying to find the perfect one", but in reality, they are all perfect in their own way!
SpyderEdgeForever
Post by SpyderEdgeForever »
Thank you Larrin. Edge-holding is important to me but my two main big properties I like in a knife steel are corrosion-resistance and toughness.
SpyderEdgeForever
By the way everyone, look which steel is nearly at the top of the chart: SANDVIK 14C28N! Just as I thought! :) :) :)
