Para won't stay sharp
kjav
Post by kjav »
Hello everyone. I can't keep my para2 sharp. I am using a Lansky sharpening system. I carried a Leek for a long time and sharpen it the same way - that knife was always sharp much longer and I believe the steel on the Para is much better. I am able to achieve a very sharp edge on the Para, but once I open the tape on 3 or so shipping boxes, the knife will no longer cut anything. The edge quickly feels like a butter knife.
I emailed Spyderco right after I got the knife asking them what angle it is pre-sharpened to and what sharpening angle they recommend but they refused to just give me a straight answer on that so I have no idea what angle I should be using. I'm using the 20 degree setting on the Lansky.
Thanks.
Re: Para won't stay sharp
Hi Kjav,
Welcome to our forum.
I would suggest a 30 degree inclusive angle. Any of our steels have no problem with that. Also the glue on tape often causes cutting issues.
Dornbox
Post by Dornbox »
sal wrote:
Tue Dec 04, 2018 9:14 am
Ha! Something I’ve noticed in the past but never quite put two and two completely together. Thanks Sal!
Too many Military family variants... and yet not enough.
:spyder:
Doeswhateveraspidercan
Hi Kjav,
Glue from the tape is the worse I hate that stuff. If this is what is fouling the blade keep some paper towels and rubbing alcohol on hand it will get rid of the evil tape goo. Is it my imagination or is that tape glue staying wet longer? Boxes I get from Amazon are miserable.
Blueboost
Post by Blueboost »
You sure it's not a clone?
Blueboost wrote:
Tue Dec 04, 2018 10:45 am
I was also going to question that. I cut through a lot of packaging tape at work as well. My M4/Rex45/M390/4V knives all get a little duller by the end of a day or two. Clean them up and touch them up and they are back to razors. Makes me wonder about the OP's knife. None of the Para 3 steel variations should dull THAT quickly.
zhyla
Post by zhyla »
It’s possible you’re creating a wire edge that appears sharp but rolls when used. I’m not familiar with that sharpener but make sure you are pushing abrasive towards the spine, not away from the spine, otherwise you can create a burr.
Ric
Post by Ric »
Please cover the edge with a sharpie. So you see what it is doing. Raise a burr on one side the flip to the other side and raise a burr again.
A cut into some wood to remove some burr and other stuff.
Strop the blade on something (newspaper, leather belt,...)
Use a coarse stone.
Try a benchstone. Here i tend to get quicker results.
Are you sure its a real Spyderco?
Burr/wire edge. I used a Lansky for years before moving on to better systems. Once you've apexed the edge, try making very light edge leading passes along the edge alternating sides. You can also increase the angle of the stones a bit by clamping the blade slightly further into the clamp and cheat your way into making a micro bevel.
This is what I was thinking too. All my PM2's & Para 3's (including the base S30V versions) all keep their edge way longer than the 14C28N Leek I have.
Pelagic
Post by Pelagic »
Evil D wrote:
Tue Dec 04, 2018 11:59 am
^^^ great advice. Do a lot of these alternating passes with very light pressure when you finish. Stropping could also help a lot, but isn't mandatory. I really hope you didn't receive a clone.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
cbrstar
Post by cbrstar »
Op I use a lansky as well but it does have one flaw. The angle changes depending on how deeply you attach it to the blade.
I think a sharpmaker is more consistent if used properly, and you can hone the blade.
FK
Post by FK »
Burr / wire edge
FK
ABX2011
Post by ABX2011 »
I'd like to see a couple pics of the knife.
Dee
Post by Dee »
Kjav-
Get a loupe.
Look at the edge.
Look at it when you think it is sharp. Look at it when you think it has come dull.
The loupe will show you what is happening.
All else is conjecture.
Dee
Robbob
Post by Robbob »
Do you recommend the same approach for any model with a secondary bevel?
Hi Dee,
Mahalo for the good advice.
Robbob wrote:
Wed Dec 05, 2018 6:42 am
Hi Robbob,
there are many opinions on this and mine is not necessarily the final answer, just what I do. I use a 30 degree on all of my Spyderco knives. though a 40 degree secondary bevel is probably stronger, I don't use one.
DBCOOPER
Post by DBCOOPER »
There is alot of play in the slots on the lansky guided system, I've found that once you have apexed while holding the rods inward most part of the slots, start again with the highest grit stone you have on the outward most part of the slots removing the Burr. That has been the best way I can remove the Burr using the lansky while also creating a small microbevel
I came here to cut sh#$ with my knives and chew bubblegum, and I'm all out of bubblegum
Robbob
Post by Robbob »
sal wrote:
Wed Dec 05, 2018 8:53 am
Hi Robbob,
I recall you saying something similar before, but I'm glad you clarified.
Thanks, Sal.
