It depends on the bonding.JD Spydo wrote: ↑Tue Nov 27, 2018 5:54 amBloke you are not the only one I've heard that uses Windex for a stone lubricant. Why might I ask is the properties of Windex ideal for abrading and honing? There is so much debate out there on what to use on benchstones and whetstones and I'm curious as to why the Windex or even kerosene for that matter>> because I have a good friend who uses kerosene on most of his stones.Bloke wrote: ↑Tue Jul 24, 2018 5:29 amI sharpen S90V and S110V at 28deg inclusive with SiC stones (Gritomatic) and Windex to 400grit on a guided system.
I don’t do anything special but I avoid burrs and keep them to a minimum irrespective of what I’m sharpening. Once I have a clean apex I finish with a freshly flattened stone with three light edge leading strokes each side, then two and a single pass each side to finish. Then three or four very light strops with chrome oxide on stiff leather and call it good.
I maintain with a SharpMaker and 40deg micro bevel off medium stones. :)
Some stones are strictly water.
The oilstones don't use water because there bonding doesn't break down as readily and the swarf would clog the stone.
These synthetic stones use a "sintered" construction.
The grains are fused together with heat and pressure.
Very minimal bonding to release grit so water doesn't work very well.
The Windex/Simply Green acts like a surfactant and decreases the surface tension of the liquid allowing it to collect and float away more swarf and prevent clogging of the pores.
The kerosene goes way back to when it used by loggers with crosscut saws. It would help clean the tree pitch off the side of the saw and was more readily available (Windex didn't exist yet :D)
It is recommend when restoring a crosscut saw to use kersone and a Norton Crystolon Axe puck.(traditional) The problem is the kersone evaporates fast . Smells bad and is flammable. So I wouldn't use that on benchstones.
Not as effective.
You can use food grade mineral oil too but that's too messy for these coarser synthetics in my experience and should be saved for natrual Arkansas stones.
The Arks should just be saved for nostalgia only IMHO. There are just much better stones available now
