Recent/upcoming steel changes
So I have two questions here; first off why switch the Native to S30V instead of switching everything else to S35VN? I slightly prefer S35VN, although the differences are minimal.
Next, will the switch to BD1N be for all US made models, all BD1 models from any origin, or is it just for the UKPK?
If the basic Manix 2 LW is going to get the upgrade, is there a guess as to when those will hit the shelves so to speak?
-David
Re: Recent/upcoming steel changes
My guess is that s30v is considerably cheaper/easier to work with than s35vn. It's probably a cost vs performance thing.
I don't know about the bd1n though. I'd also like to know which models are getting it.
We will more than likely change to BD1N for all models. Still deciding on S30V / S35VN.
S35vn is by design an easier to work with s30vFrozenspyder wrote: ↑Sun Jul 22, 2018 10:06 amMy guess is that s30v is considerably cheaper/easier to work with than s35vn. It's probably a cost vs performance thing.
Phaust-
Interesting. I learn more here every day. I wonder why s35vn isn't more common then. I'm sure they had a good reason to switch to s30v for the native, at any rate.
Sal-
Good to know about the bd1n. Thanks for keeping us all in the loop.
Sal-
- MichaelScott
I would conjecture that if S35V is only marginally “better” than S30V and more difficult (therefore costly) to work with, Spyderco would stay with S30V. That ignores the marketing potential of offering an “upgraded”steel at a higher price to cover their added manufacturing cost.
I like BD1N and am glad it will replace other basic steel. My limited experience is that I can get it a bit sharper for longer.
http://acehotel.blog
Team Innovation
Team Innovation
I wonder if there is a supply problem with S35VN? Still, the slight differences in the steel (regardless of all the hype) may not make it worthwhile to utilize since it is not significantly different. From a dollars and cents standpoint, it makes more sense to stick with one or the other, not both S30V and S35VN.
As for the BD1N, I am actually quite excited to be able to try this steel. I have never used it. I want a Manix 2 LW so I can compare apples to apples.
Thanks for the info Sal!
-David
S30V vs S35VN
According to the producer of these steels, Crucible,
S35VN is 20% tougher than S30V in the Charpy C notch test.
Catra wear resistance testing is equal.
Corrosion resistance is equal.
S35VN is easier to machine in its annealed state than S30V.
Target hardness for both is 58-61 hrc.
Recommended Heat treatments are the same.
http://www.crucible.com/PDFs/DataSheets ... 202010.pdf
http://www.crucible.com/PDFs/DataSheets ... v12010.pdf
This creates a tough decision. Do I buy a polestar now in case they end up being discontinued or wait for a bd1n model?
I must be missing some earlier conversation here.
Is the “S30V / S35VN” distinction meant to suggest we will have only one of them in future? And, therefore, that BD1N Is destined just “for all models” now in BD1?
I can’t imagine S30x ever falling out of Spyderco’s favor unless Crucible has signaled it will raise prices once imported steels get more expensive under tariffs. But then, why wouldn’t Carpenter do the same?
- MichaelScott
I think when they are gone there will be no more. Too many people won’t spend the extra $20USD for it over a Tenacious. A completely irrational decision because that is two six packs, or a movie for two or a basic cheap dinner out.Frozenspyder wrote: ↑Sun Jul 22, 2018 1:08 pmThis creates a tough decision. Do I buy a polestar now in case they end up being discontinued or wait for a bd1n model?
You actually have to have one for a short while to appreciate what a well made and refined design it is. I would think that this is also true of the Alcyone. I wanted a bigger knife to compliment my smaller ones so,I got the Polestar. Either are excellent but under appreciated knives so they probably won’t be making them again. I’d say get one while you can.
Team Innovation
Team Innovation
- knivesandbooks
I just got my first bd1 knife, the Polestar, and I'm happy to say I like this stuff. Very similar to vg10. In fact, i think it gets less of a wire edge than vg10. I'm very interested in trying bd1n now, especially if the put it out in a g10 handle model.
Thanks, MichaelScott. I appreciate your input. I think I'll have to pick up a polestar soon. It sounds like it's not a model I'd want to miss out on.
- MichaelScott
You are welcome. I hope you like it as much as I do. After you’ve had it for a while I think you will appreciate the design quality of it.Frozenspyder wrote: ↑Sun Jul 22, 2018 6:23 pmThanks, MichaelScott. I appreciate your input. I think I'll have to pick up a polestar soon. It sounds like it's not a model I'd want to miss out on.
Team Innovation
Team Innovation
- curlyhairedboy
Adding my vote in for S30v over S35vn.
- steelcity16
When changing steels I believe it is vital that the upc and/or model # is changed. It is creating great confusion and dissapointment among dealers and customers when a model is changed substanially with no change to the upc or model #. Look at the chaos created with the Mass Drop Blue Box Native. I am trying to track down a pre-CQI S35VN G10 Native with stainless liners. A lot of dealers still have S35VN with Stainless liners in their description, but the actual inventory they have is post CQI and has the S30V blade and linerless G10. I ordered a Native from UnitedOutdoors and stated in the best offer to only accept if it was the S35VN version they would sending me. They accepted and sent me the S30V version and seem confused as heck as when I tried to explain the change and that they need to look at the physical knife for a stamp of S35VN to know which knives they actually have in inventory.
If im putting myself in the dealers shoes, if i had 100 S35VN Natives in stock and received a new batch of 100 S30V knives with the same code it would be a nightmare. Id have to create a new listing for the same UPC and have two different steels and sell them simultaneously. Then store them separately and have them clearly labeled as to which ones were S30V amd which ones were S35VN.
Maybe it isnt as hard as Im making it out to be, but trying to track down an actual pre-CQI S35VN Native G10 has proven difficult, especially when a lot of dealers are still listing this model as having S35VN and only have S30V in stock.
tl/dr - please issue a new UPC and/or Model # when making a permanent steel change to an existing model to avoid confusion
steelcity16 wrote: ↑Mon Jul 23, 2018 11:29 amWhen changing steels I believe it is vital that the upc and/or model # is changed. It is creating great confusion and dissapointment among dealers and customers when a model is changed substanially with no change to the upc or model #. Look at the chaos created with the Mass Drop Blue Box Native. I am trying to track down a pre-CQI S35VN G10 Native with stainless liners. A lot of dealers still have S35VN with Stainless liners in their description, but the actual inventory they have is post CQI and has the S30V blade and linerless G10. I ordered a Native from UnitedOutdoors and stated in the best offer to only accept if it was the S35VN version they would sending me. They accepted and sent me the S30V version and seem confused as heck as when I tried to explain the change and that they need to look at the physical knife for a stamp of S35VN to know which knives they actually have in inventory.
Think of the poor sods who want a linerless S35VN N5!!
-David
