The Return of S60V/440V
steelcity16
Re: The Return of S60V/440V
Post by steelcity16 »
JD Spydo wrote:
Thu Jun 14, 2018 6:31 pm
sal wrote:
Thu Jun 14, 2018 10:15 am
Hi Shawn,
Spyderco was the first production company to use Crucibles particle metallurgy in production knives. I personally went to Crucible with crew to begin the project in the mid 90's. We began with S60V while is was still being called CPM 440V. We had no problem getting it hard, but in a hi 50's to low 60's it was so brittle that it would crack if dropped on concrete. We continue to experiment until we reached the conclusion that 55/56 worked best for the steel in knife blades. In the end, we dropped it. It was too hard to sharpen for customers, though edge retention was good. I don't think we would use it again.
Now please Sal don't throw out the "baby with the bathwater" because I still maintain that 440V is still one of the better blade steels you guys used for Spyderedged blades. I will admit for as hard as it was to sharpen>> to be truthful it was a "MONSTER" to sharpen in plain edge :eek: But I still use two of the older full Spyderedged models in 440V and it's truly one of my all time favorite blade steels for Spyderedges IMO.
Being that most of it only tested out at 55 to 56 on the Rockwell scale probably explains to me why it was such a good blade steel for Spyderedges. I hope to get my hands on one of the older 440V, full SE Military models again some day. That was a true beast of a serrated blade in 440V.
I guess what I'm trying to say is that if you all ever get anymore 440V you can at least use it in Spyderedged blades. I rank it along with ATS-55 and AUS-8 as being my top 3 favorite blade steels for Spyderedges.
I just purchased an old Golden-made Native in 440V SE due to this reply and your love of 440V SE in some old threads. I hope it lives up to the hype! ;)
Deadboxhero
Post by Deadboxhero »
I feel s60v is definitely worth revisiting.
As it offers a nice range in performance for people wanting more cutting performance then s30v but a little more versatility then s90v.
Much like an "American Elmax"
I feel the problems the steel was having in the early 2000's were due to the growing pains of the industry and that the "kinks" have been worked out.
This is CPM s60v at 60-61 HRC
2050f Austenizing temp. protected in foil from decarbing and soaked for 20min, plate quenched. No Cryo and a few tempers at 350f for two hours each temeper.
The steel was still able to reach 60-61 HRC tempered with no cryo and no oil quenching.
This is significant because in the past there were issues with hardenbility.
I've talked to the sales representative at Crucible and he has told me there have been minor adjustments to the melt and that there steel making process has been very much improved after the company reorganized about a decade ago.
Niagara Specialty Metals has also been improving there rolling and annealing process alot since the early 2000's.
The steel is also very much available as well unlike Elmax, also less cost and domestic.
I ground the blade with a rough grind and Sharpened it to 17 dpson a 1500 grit CBN waterstone.
The shoulder of the bevel was 0.010" behind the edge (bte)
The edge came up alot like Elmax does at this hardness as well.
I then took the sharp thin edge and abusively cut the edge into a .25 brass rod and twisted the cut out.
At 0.010" bte and 60-61 HRC and cutting with a heavy hand I could even see some flexing behind the edge. With enough cutting the Apex definitely took some chipping which is expected with a high alloy, high chromium, high Carbon PM steel at this geometry.
Definitely not the extreme brittle behavior described in the past.
I went back to the 1500 grit CBN stone (which behaves more like a 2k grit/7 micron stone) and was able to see the damage better.
Rather then waste time I just jumped down to a 400 grit CBN waterstone and used a few rapid back and forth passes with moderate pressure to remove the damage in seconds rather the spending a few minutes at 1500 grit.
I then jumped back to the 1500 grit CBN to add more push cutting ability to the edge and polish the apex more.
After a 1um diamond stroping the edge was where I liked, a nice blend of polish and tooth with the ability to tree top and crop free hanging hair, yet still have a nice bite to the edge.
I feel this steel should be revisited. The times have changed.
Big Brown Bear
Triple B Handmade Knives
Pelagic
Post by Pelagic »
Very interesting.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
blues
Post by blues »
Shawn, I haven't read through the entire thread so forgive me if this has been mentioned, but in discussions I and others have had with Tony Bose, he's often stated that 440V is / was his favorite knife steel.
The man does know a bit about making knives. ;)
- Retired from the chase -
JacksonKnives
Post by JacksonKnives »
More steels are better, but for me it's still the elusive combo of ideal geometry, ideal ergonomics and ideal maintenance schedule for a specific task.
EDC is an ambiguous role, and none of my pocket-carry knives see consistent tasks beyond opening and breaking down cardboard boxes. Wear resistance is a big deal, but edge stability for thin grinds helps the task just as much, so everything comes out in the wash. I like S90, ZDP, etc... But I also like Super Blue and 52100.
I've seen much bigger gains changing up my sharpening geometry (And buying knives from a maker like Spyderco, where grind geometry seems to be an important part of the design process) than experimenting with different steels, but... I'll not complain about more steels to choose from. :)
Hey Jackson,
Will you be making knives in S60V?
Post by JD Spydo »
I still maintain that 440V/S60V is still in my top 5 favorite blade steels for Spyderedges. I sort of liked it in plain edge but it really perfoms well in Spyderedge and I still have some 440V SE blades that I plan on keeping. Especially my 440V, SE NATIVE model which to me is truly a pitbull of a knife.
I would very much welcome any Sprint Run of 440V in Spyderedge. Because that's where that steel really stands out in my humble opinion. And believe me I've had a ton of experience using all the different steels in SE. Now I will say that 440V is truly a "monster" to sharpen and you will more than likely use a lot of curse words :rolleyes: while sharpening a 440V blade. But with Spyderedges you won't have to do it very often.
I still keep my radar out for the GOLDEN made SE models with that steel.
Deadboxhero
JD Spydo wrote:
Mon Sep 17, 2018 3:59 am
I'd be interested in trying some of the older 440v spyder stuff, I keep hearing it's hard to sharpen. This s60v was a breeze, especially compared to what's on the market today. Even from Spyderco
Big Brown Bear
Post by JD Spydo »
Deadboxhero wrote:
Mon Sep 17, 2018 11:05 am
Brother if you can ever get your hands on any of the older GOLDEN made Spyderedged models you won't regret it. I personally guarantee that you will be impressed with the overall performance of a Spyderedged 440V Spyder. The Military and the Native are two of the best I've ever used in 440V Spyderedge. Even the combo edged GUNTING model in 440V was a great one too. The three best blade steels that Spyderco used for their Spyderedged blades are 440V, ATS-55 and AUS-8. Also the old GIN-1 in SE wasn't bad either. But you will not go wrong with 440V SE Spyderco models>> I personally guarantee it :cool: ;)
ferider
Post by ferider »
Deadboxhero wrote:
Thu Jun 14, 2018 9:55 am
A shame since my curiosity is burning a hole through me.
I'll update this thread with testing soon.
From an older photo, my one and only 440V knife, BBB. To be honest, when I use it, I forget about the steel, handling this thing is quite unique :)
On the stone, it feels kind of in between a good D2 (different but US make) and Spyderco S30V, if that makes sense.
Thanks,
Roland.
Deadboxhero
JD Spydo, Noted that's brother :D
Ferider, yea man, maybe I'll see one at blade show west
Big Brown Bear
Sjucaveman
#32
Post by Sjucaveman »
Deadboxhero wrote:
Sat Sep 15, 2018 3:59 pm
Not to derail this thread but have you ever tried this with s110v or maxamet two of the high wear steels that aren't necessarily known for toughness? I would understand if you have no wish to do whatever damage may happen to those blades.
Adam
#33
Post by JD Spydo »
ferider wrote:
Tue Sep 18, 2018 7:59 pm
Holy Archives Batman!! I haven't seen or had one of those original 440V, original Chinook I models in my hand since about 2006 or thereabout. The Chinook III has been my all time favorite out of the entire bunch but I've always loved the design architecture of the original Chinook.
When you think about it the 440V era which ran parallel with the ATS-55 era was a very interesting pivot point in Spyder History.
No 440V is not hard or difficult to sharpen :p IT's An Absolute MONSTER To Sharpen. I can't tell you all how many new cuss/curse words I made up while sharpening all my 440V Spyders. That stuff was even beyond aggravating to even reprofile. But for Spyderedged blades I don't know of many other blade steels that I like better than 440V/S60V. What is strange about it is that 440V is even significantly harder to sharpen than many of the newer/better blade steels that we've been blessed with in the past 7 years or so. But it's an era in Spyder-History I won't forget anytime soon. I really cut my Spyder-Baby Teeth during that era :cool:
Deadboxhero
#34
Sjucaveman wrote:
Wed Sep 19, 2018 5:57 am
I have a considerable library of YouTube videos showing the limits of Maxamet and s110v Spyderco knives.
Big Brown Bear
#35
Post by JD Spydo »
At one of the BLADE shows I got to chat with one of Crucibles sales persons. They told me that 440V ( S60V) was mainly marketed to the "Tool & Die" industry. He explained how it had properties that was highly desired for those types of uses.
I will always like it for Spyderedged models and even as difficult as it is to sharpen I still find it to be ideal for hard use in SE. I've also wondered at times how it would have been for hawkbill blades. I've also often wondered if that 440V (S60V) would be good for woodworking tools?
Deadboxhero
#36
I completed an s60v knife at 60-61rc. It's not brittle. Not fun to hand sanding though.
I'd like to see this steel revisited in a Spyderco. Hits anice sweet spot. I have another S60v blade at 62-63rc that I haven't tested. I'm curious to see what s60v is like that hard.
Big Brown Bear
#37
Nice looking knife Shawn. Let us know how it holds up.
Deadboxhero
#38
sal wrote:
Thu Nov 15, 2018 1:31 pm
Thanks Sal, it will be interesting to see how the 62-63 rc performs
Big Brown Bear
blues
#39
Post by blues »
That looks like a great utility knife for kitchen or other tasks since the handle will allow the whole blade to be utilized.
Form follows function. :cool:
Deadboxhero
#40
blues wrote:
Thu Nov 15, 2018 2:02 pm
It's built for freehand Sharpening too. It's easy to run on a stone.
Big Brown Bear
