JD Spydo wrote:Ankerson wrote:Stropping is OK for quick touchups in field etc, but there are drawbacks as every time you use that strop you will lose some edge retention every time you do it. So normally about 3 or 4 times using it then refresh the edge.
With the ceramics that's not a problem so I don't NORMALLY use a strop.
You've really got my curiosity going now Ankerson :) Because you and Cliff Stamp both have made that case over the years and now I'm wondering why stropping would cause you to lose some of the "edge retention" :confused: Hey you and Cliff I think have both forgotten more than I've learned so far so I'm open to hear why you think that is?
Because I've been using 3 different strops with my M390 Military and I've been having great results. But maybe I should just go with stones only for a while to see if I could notice the difference
Also this coincides with some information that I've gotten from another website recently. I've heard that doing a final finish on an Arkansas Stone (novaculite) actually does better than stropping
Also another item of interest is that it has been mainly Barbers using strops on straight razors for years before I heard of the knife community using them for edge enhancement. Actually I do find all of this interesting. Maybe Surf can thumb his nose at me after all :D
Well I will try and make it simple. :)
When a knife is used to cut stuff the apex gets worn, rolls or gets damaged, ths happens with ANY steel on ANY knife.
Now when that happens the apex is larger than before (thicker).
Stropping straightens the edge.... This is the same edge as above now, the one with the thicker apex.
Given the strop staightens the edge and that also bends the steel back into place (weakening the edge) kinda like bending a paperclip back and forth.
Now what we have after stropping is a thicker, weakened, damaged apex.
So each time the strop is used take the above and multiply it again and add a certian percentge as it will be worse each time.
