Military in s35vn??
Military in s35vn??
What do you think are the chances and likelihood of this being produced?? I want one!!
- michaelm466
Exactly, so more than likely if the change ever comes to be permanent it'll be more about cost than performance, or suffice to say if they deem S35VN to be as good as S30V and the price is right then it'll happen.michaelm466 wrote:eh, for me its too similar to S30V to be an interesting sprint, as far as performance they're both too close too tell apart really, besides perhaps a very slight difference in ease of sharpening going to S35VN. I have the S35VN PM2 and it seems just like S30V to me.
- avocadobbq
Wasn't S35V just supposed to be an easier to manufacture version of S30V? I remember reading performance tests that it's actually slightly worse than S30V in some regards.
I can understand people being steel knuts to a degree, but wanting something just because the number's higher I don't agree with.
Was S35VN really hyped that much? I just took it as a slightly refined S30V.Evil D wrote:I think if S35VN ever lives up to the hype it could possibly replace S30V as the standard Golden steel, but as of yet i don't think it's live up to the hype. That could just be that the hype is quite large though.
- chuck_roxas45
Ankerson wrote:If they are going to make a change from S30V I would rather see CPM 154.
Popsickle wrote:+1
Elmax?xceptnl wrote:+2
- chuck_roxas45
I think they are talking about CPM154...Evil D wrote:154CM is a step backwards if you ask me.
It's time they move on from S30V IMO
I would personally like to see them make the standard issue C-36 Military model in either CPM D2, CPM-M4 or one of the Carpenter steels like XHP which is the Mili I currently own at this time and love it dearly.
I think that the Military has had it's run with S30V and it's time to move on even if they only rachet it up to S35V. The Mili has been made with S30V for over 9 years now and it's really time for a change I believe. And I know I'm not the only one that thinks so. And I do believe it would catapult the sales of that model very nicely if given the chance.
I would even love it if they would run the Military in either Udderholm or one of Timken's steels just for a change.
Only if it could be done without increasing the price would I be for a steel change (and not to S35vn even if it is cheaper). As the price increases, the ability to replace it if something happens decreases, and I feel part of the Military's status as 'the only knife you need' would be undermined to some degree if the price of a replacement would make you too fearful of having it lost, stolen, accidentally broken, whatever.
Plus the Military has had and probably will have plenty of sprints in steels with better retention available to those who are looking for that at a higher price.
JD Spydo wrote:I would personally like to see them make the standard issue C-36 Military model in either CPM D2, CPM-M4 or one of the Carpenter steels like XHP which is the Mili I currently own at this time and love it dearly.
S35VN isn't an improvement over S30V, performance is about the same for most general use, but if the knife will be a real user that sees a lot of cutting S30V still has the edge in edge retention.
My recommendation of CPM 154 would be an improvement over S30V because it can be run at a higher hardness than 60 HRC so one would see an improvement in edge retention.
CPM 154 is an interesting steel in that it was developed for the Custom makers to be easier to work with than S30V, but what happened was it was really an improvement over S30V and turned out to be a better steel than they thought it would be.
