At a glance
1.98in 50mm
CPM® SPY27®
Japan
R.I.L.
About
Designed by custom knifemaker Ed Schempp, the appropriately named Balance is a study in symmetry. Closed, it is a compact expression of perfect equilibrium. Open, it is an amazingly ergonomic tool that cuts with the authority of a much larger knife. Originally introduced in 2010 and later discontinued, this remarkable design is back as a limited-edition Sprint Run model. Its downturned blade is full-flat ground from Spyderco’s proprietary CPM SPY27 stainless steel and includes a generous index-finger choil to provide exceptional control during use. The satin-finished blade is paired with a unique handle featuring a stainless steel scale on one side and a stainless liner and peel-ply-textured G-10 scale on the other. The stainless scale is precision machined to create a sturdy Reeve Integral Lock (R.I.L.) mechanism, while the G-10 scale is cobalt blue—one of the signature hues of our CPM SPY27 family. Both scales provide mounting holes for a stainless steel pocket clip that is reversible for left or right-side tip-up carry.
Technical specifications
Lock
R.I.L.
Blade Length:
1.98in 50mm
Overall length:
4.49in 114mm
Closed length:
2.66in 68mm
Edge Length:
1.22in 31mm
CPM® SPY27®
Blade thickness:
.08in 2mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
Stainless/G-10
Knife weight:
1.4oz 40g
Grind:
