At a glance
3.68in 93mm
H-2
Japan
Back Lock
About
The Spyderco Assist™ Salt® combines the extraordinary lifesaving features of the innovative Assist model with the ultra-corrosion-resistant qualities of H-2 blade steel. The result is a multi-function, purpose designed rescue tool ideal for use in and around the water. Its remarkable features include a blunt tipped CombinationEdge™ blade, a recessed carbide glass breaker, a reversible wire clip, a built-in survival whistle, and the capability to scissor cut rope using the handle’s ergonomic finger grooves. The hollow-ground blade’s fully accessible Trademark Round Hole™ allows easy one-handed opening, even with gloves, and is supported by a sturdy back lock mechanism.
Technical specifications
Lock
Back Lock
Blade Length:
3.68in 93mm
Overall length:
8.42in 214mm
Closed length:
4.87in 124mm
Edge Length:
3.15in 80mm
H-2
Blade thickness:
.12in 3mm
Tip carry position:
Tip-Up
Clip position:
Ambi
Handle material:
FRN
Knife weight:
3.9oz 111g
Grind:
Hollow
