Results 1 to 11 of 11
Thread: cheap sharpening for byrd hawkbill
  1. #1
    Spyderco Forum Registered User
    Join Date
    Feb 2014
    Posts
    11
    I am trying to spruce up my hawkbills edge before turkey season. It stands to reason if I bought a 20 dollar byrd knife I am not going to go spend 60 on a sharpener. I have a lansky system with 3 stones that works ok for my plain edge knives. Are there any cheap ways to sharpen the curved serrated blade, as in less than the price of buying a new knife. I was thinking a welding rod would fit the larger serrations nicely.
  2. #2
    Join Date
    Feb 2014
    Posts
    83
    DMT Diafold Serrated is $23 on Amazon - http://www.amazon.com/DMT-FSKF-Diafo...nife+sharpener. A Smith's pocket pal with a similar tapered rod is 9 bucks and change - http://www.amazon.com/Smiths-PP1-Poc..._bxgy_hi_img_z.
  3. #3
    Spyderco Forum Registered User Donut's Avatar
    Join Date
    Sep 2009
    Location
    Virginia Beach, VA, USA
    Posts
    6,500
    Don't most lansky systems come with a triangle shaped stone? You might be able to get that to work.
    -Brian
    A distinguished lurker.
    Chat with us. Sharpthings - A Blog Site
  4. #4
    Join Date
    Aug 2013
    Posts
    62
    I have a Byrd hawkbill.
    First off you don't sharpen the ground side, you sharpen the flat side. I do so on a sharpmaker rod and then remove the burr (formed on the ground side) on my buffing wheel. You could use the quartz-ceramic rod out of a burned out high pressure sodium buld or even sand paper around a dowel rod.
    I find it one of the easiest knives to sharpen, all in all takes 5 minutes of work to bring it back to shaving from pretty much blunt since you only have to work on the one side and don't have to worry about maintaining any specific angle.
  5. #5
    Join Date
    Feb 2014
    Posts
    11
    The lansky system i have only has 3 stones for flat blades the triangle stones are available. I dont really care for the lansky because it reprofiles at an arbitrary angle rather than just touching up the factory geometry. And takes off alot of steel. This is probably picky for someone who was gonna sharpen with a fluxcore rod.
    If i only sharpen the flat side Im changing it from a chisel grind to one ground on both sides correct?
  6. #6
    Join Date
    Aug 2013
    Posts
    62
    No, just sharpen it like a PE chisel grind (or a scandi grind), without changing the bevel any but then instead of flipping it over and doing the ground side you just make a few passes on a buffing wheel and your done. Really man trying to file each individual serration is the wrong way to go about it and about 300% more work.
    Check out this thread of BFC, specifically post #11 by knifenut1013
    http://www.bladeforums.com/forums/sh...ning-SE-blades
  7. #7
    Join Date
    Feb 2014
    Posts
    11
    I get what you are saying after reading that. I think I am over thinking it. http://www.amazon.com/Lansky-Spyder-...=lansky+spyder I found this too. This knife stayed sharp for a long time, its been a good one for me..
  8. #8
    Spyderco Forum Registered User xceptnl's Avatar
    Join Date
    Feb 2011
    Location
    Moonshine Country, Virginia
    Posts
    5,404
    It has been a long time since my first real inexpensive sharpener, but the Kershaw 2535 Ultra-tek worked really well for me for quite a few years before I lost it. Tapered edges for the serrations, and a wide oval top for the hawkbill. Great 600 grit diamond sharpener for $25 and very portable also.
    My 's:
    Native, Manix 2 (BD1,154CM,S30V,M4,XHP,S110V,Cruwear), Delica 4 (White,Red,Brown,Blue,BRG,G-10), Spyderhawk, D'fly (H1,G-10,SB), Police3, Volpe, Military (S30V,XHP,D2,M390,BG42,440V,Cruwear), Superleafs, Forager, D2 Para, Kopas, Kiwis, Caly (JR's,3,3.5), Para2 (XHP,204P), Stretch (SS,FRN's,CF), Rescues, Dyad Jr, Pingos, Southard, AIR, Jess Horns, Forum N5, Lil Matriarch, Barong, Superhawk, Chinook II, ATR, SPY-DK, Captain, Ti UKPK, Mules
    *Landon*
  9. #9
    Spyderco Forum Registered User araneae's Avatar
    Join Date
    Aug 2006
    Location
    South of the Erie shore, Ohio
    Posts
    3,849
    Really if you think about how long you will have the sharpmaker, $60 is a tiny investment and well worth the cash.
    So many knives, so few pockets...
    -Nick
    Light Modding and Wharnifying when time permits
    Just got: Superblue D'fly
  10. #10
    Spyderco Forum Registered User opusxpn's Avatar
    Join Date
    Mar 2014
    Location
    South Texas
    Posts
    348
    I use this one sometimes for light touch ups it works https://lansky.com/index.php/products/spyder-sharpener/
    But I love my sharpmaker it is worth the money
    Keep 'em sharpEndura4 (blk all edges, brwn, FG, SB, RG ZDP, blk tac, wave) Salt1 (blk, yllw PE H1)Tasman(yllw SE H1) Pacific salt(blk SE H1) Stretch(ZDP, SB) Delica4(blk CE, wave, SB) Drgfly2(yllw SE H1, org PE,SB PE) Pingo(blk) Cat G10(blk) Centofante3 Ldybg3(FG,SB,Hwk yllw H1, tan H1, blk) Manbug (blk SE, SB) Manix2(Ltw trans blue PE, G10 PE, Ltw dark blue frn) Para2(dig/satin, blk/satin) Military(Cru-Wear) Resilience, Tenacious(blk CE,grn PE), K04 Blk PE, K04 Blue SE, Byrd Robin2 G10
  11. #11
    Spyderco Forum Registered User HellHound's Avatar
    Join Date
    May 2010
    Location
    Lithuania,Europe,Earth.
    Posts
    490
    The cheapest way ever would be find a ceramic mug and turn it over see if theres a sharpish ceramic surface on the bottom of the rims, theres your free sharp maker. Alternatively if your bored in your car roll down the window and touch it up on the upper side of the glass, same rough ceramic surface, also it's curved out so it should sharpen your hawkbob no prob, now it's not as course so you be patient if it's very dull.
    thewannabesurvivalist
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
