Results 1 to 13 of 13
Thread: Cara Cara Blade Rubbing When Closed
  1. #1
    Spyderco Forum Registered User
    Join Date
    Dec 2013
    Posts
    23
    When I close my New Cara Cara, I noticed that the belly of the blade at the end, rests on the handle inside. I think it's the piece that holds the spring.
    Anyway, I was just wondering if that is normal. I know some knives have extra pins, or a raised part near the hilt that keeps the blade "floating" when closed.
    I'm thinking of putting a little piece of felt or cork there, but if it's a defect then I'd prefer to send it back.
  2. #2
    Join Date
    Dec 2013
    Posts
    23
    I don't know what a slip joint knife is, but the lock works fine.
    The problem is that the kick is to small and the edge of the blade rests on the inside of the handle when closed.
  3. #3
    Join Date
    Jan 2012
    Location
    NZL
    Posts
    647
    Normally the edge should not bottom out in the handle, it will blunt the edge and/or mess up the inside, as you say the kick off the ricasso should be the only point of contact. I would consider that a defect, but you will need to contact the seller/manufacturer to say for sure.
  4. #4
    Join Date
    Dec 2013
    Posts
    23
    Yeah, I sent it in.
  5. #5
    Join Date
    Sep 2004
    Location
    Golden, Colorado USA
    Posts
    7,254
    Hi Morgoroth,
    Sorry for the hassle. thanx for sending it in.
    Hi Arda,
    Welcome to our forum.
    Join Date
    Dec 2013
    Posts
    23
    No worries, it would be a hassle if I had paid for a knife from a company that doesn't back their product. :-)
  7. #7
    Join Date
    Dec 2013
    Posts
    23
    I got the knife back and I think the letter says there was no defect which is a little confusing.
    I'm going to try calling the number Monday to see if I can find out exactly what they did.
    I know the clip was replaced and it was sharpened, but I'm not sure they took it apart to see the rubbing.
    Also, I'm not sure how to check to see if it's fixed without taking it apart, and I don't really want to void my warranty just yet.
    I can still see the notch the blade put in the spring retainer so I know it was rubbing.
  8. #8
    Join Date
    Nov 2013
    Location
    Madrid, Spain
    Posts
    37
    Hello.
    Perhaps you could put some acrylic paint on the edge and ensure whether there is a contact point or not.
    Regards.
  9. #9
    Join Date
    Dec 2013
    Posts
    23
    That is a good idea.
    I'll have to try that tonight.
    Thanks!
  10. #10
    Spyderco Forum Registered User CaliMarine's Avatar
    Join Date
    May 2013
    Location
    Los Angeles, CA
    Posts
    21
    Quote Originally Posted by Morgoroth View Post
    I'm curious what they said. Please share. By the way, why didn't you just return it to the retailer instead and save all this expense and grief. I don't have this issue with my cara cara.
  11. #11
    Join Date
    Dec 2013
    Posts
    23
    I would have but it was a gift, and I didn't have any info on where it was purchased. I didn't get much info from Spyderco. I thought they would replace it but they didn't. Best I can tell, they replaced the broken clip and sharpened it. I don't think they opened it up and I'm not sure how they would have fixed the rubbing issue with out opening it.
  12. #12
    Join Date
    Mar 2012
    Location
    Austria
    Posts
    217
    I had this kind of problem with my Robin G10. The backspacer holding that lock spring was dimensioned just a bit too big.
    I do not recommend anyone voiding their warranty by modifying their blades.
    For me the way to make this knife my preferred EDC was taking it apart and grinding off 1/2mm of the backspacer where it hit the edge. I probably would not have tried it if the knife value wasn´t far less than shipping cost to and from USA but it solved the problem and let me enjoy my knife.
  13. #13
    Spyderco Forum Registered User opusxpn's Avatar
    Join Date
    Mar 2014
    Location
    South Texas
    Posts
    195
    I had something similar happen on my Robin2 G10 its an awesome little knife, actually the lock arm that goes in the blade notch to lock it open was to large and not finished so well it was very difficult to open the knife I cut my thumb finger trying to open it one handed after being cleaned and oiled.The screws were hard to take off I bent two of my torx keys, I replaced them screws and went to town on the arm sanded it down polished it. Now its smooth opening and closing plus I can take it down for cleaning if I need to. Sometimes you have to take matters in to your own hands.
    Keep 'em sharp Endura4 (blk all edges, brwn, FG, SB, RG ZDP, blk tac, wave) Salt1 (blk, yllw PE H1)Tasman(yllw SE H1) Pacific salt(blk SE H1) Stretch(ZDP, SB) Delica4(blk CE, wave, SB) Drgfly2(yllw SE H1, org PE) Pingo(blk) Cat G10(blk) Centofante3 Ldybg3(FG,SB,Hwk yllw H1, tan H1, blk) Manbug (blk SE) Manix2(Ltw trans blue PE, G10 PE, Ltw dark blue frn) Para2(dig/satin, blk/satin) Resilience, Tenacious, Byrd Robin2 G10
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
