Results 1 to 8 of 8
Thread: changing clip position
  1. #1
    Spyderco Forum Registered User
    Join Date
    Apr 2013
    Posts
    3
    I have a reslience (sp?) and want to change the position of the clip - please tell me the bit needed to back off the screws - it looks like a star bit but none of my many bits are that small.
    jnich
  2. #2
    Join Date
    Mar 2011
    Location
    Middle Earth
    Posts
    3,463
    I am at the office and have a Resilience at home so I can't check it.
    Honestly, I never know any of the sizes of any screws. I have several
    small tool sets and simply switch bits until I get the one that works.
    If you don't have a tool that works, take your knife into a Lowes or similar
    and search for a tool that fits, then you can get it, or fix it there. Heck, a
    car parts store might do it, or find a tool that works.
    Welcome to the forum.
  3. #3
    Spyderco Forum Registered User CarbonFiberNut's Avatar
    Join Date
    Mar 2013
    Posts
    410
    I'd recommend going to a hobby shop or hardware store and buying a set of extremely small Torx bits - they are well worth having. I have a small screwdriver with a set of tiny torx bits that store inside the handle. Quite handy.
  4. #4
    Join Date
    Mar 2013
    Posts
    10
    It's most likely a T6 torx lowes or Home Depot should have something that will work.
  5. #5
    Banned
    Join Date
    Apr 2013
    Posts
    92
    I believe it's a T6.
  6. #6
    Administrator
    Join Date
    Sep 2004
    Location
    Longmont, CO USA
    Posts
    1,221
    The folders in the Value Series (Tenacious, Ambitious, Resilience, and Persistence) originally used metric Allen (hex) screws. The tool for them is a 1.5mm Allen wrench. Recently, we have begun using Torx ("star") screws in those. For those you'll need a T-6 Torx bit, though sometimes a T-7 provides a tighter fit on those screws.
    For more information on the clip-switching process, please check out pages 81-82 of the 2013 OpFocus catalog.
    I hope this helps.
    Stay safe,
    Mike
    Michael Janich
    Spyderco Special Projects Coordinator
    Founder and Lead Instructor, Martial Blade Concepts
  7. #7
    Join Date
    Mar 2011
    Location
    Middle Earth
    Posts
    3,463
    I checked last night and the T-7 actually worked fine on mine. You have to be careful
    on these though, if you start with the wrong size, you can strip the head . I know that
    I have. I have been known to get impatient and think thatI have the right bit and realize
    later that it might not have been right. It seems like the T-6 wa a bit loose and T-7 a bit tight.
    Also, when you put the clip back, a little blue loctite on the threads helps hold it, so that you
    don't have to re-tighten it and make the head worse. I used some blue last night after checking.
  8. #8
    Join Date
    Apr 2013
    Posts
    3
    Thank You Spydercoians
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
