Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 142
Thread: Blervís Semi-Comprehensive Flashlight Guide (VERY Long)
  1. #81
    Spyderco Forum Registered User Donut's Avatar
    Join Date
    Sep 2009
    Location
    Virginia Beach, VA, USA
    Posts
    6,540
    That's a good point. There are a lot of factors that determine the exact size of the cell. With any production environment, you have plus and minus on everything.
    -Brian
    A distinguished lurker.
    Chat with us. Sharpthings - A Blog Site
  2. #82
    Spyderco Forum Registered User Blerv's Avatar
    Join Date
    May 2009
    Posts
    10,124
    Yea typically I just look up the light in question on Candlepower Forums or Budget Light Forums and see what people are using. If the cell is satisfactory I just go with that. Most my cells are AW Li-co's or IMR's and those are generally small compared to the high capacity other brands.
    Blake
    Listing of Blade-Length Laws by State/County (Not My Website)
    http://www.handgunlaw.us/documents/USKnife.pdf
  3. #83
    Join Date
    Sep 2012
    Location
    Port of Europe
    Posts
    84
    About RCR123A
    There are a huge amount of troubles with rechargeable RCR123A batteries. Overheating, defective, leaking, exploding . .
    Reason is that the main (quality) manufacturers like Sanyo and Panasonic donít produce cells in the format usable for RCR123A. Therefore the batteries that are made in this format need to come from lesser manufacturers and are mostimes mediocre.
    Second reason is the low C-rating of these batteries. Too low for powerful flashlights we have today. That means they are underperforming (low endurance) and also overheating easily.
    The right way of choosing a flashlight should begin by choosing the battery-type.
    1] First ask yourself how you will use it? In what way?
    2] Then you choose a battery-type that fits your use.
    3] Now you are able to look which flashlights are available to choose from.
  4. #84
    Join Date
    May 2009
    Posts
    10,124
    Pushing a RCR123 at 2c or a CR123 at 1c with some is very easy. As you mentioned this can be dangerous. I don't think even with Panasonic or Sanyo's touch it would be any safer; Lithium cobalt cells like AW are extremely well made but are against capacity and chemistry limitations.
    The real answer with any high-current light and smaller cells is to go with an IMR. In theory you could run a IMR16340 at 4 amps with no problems besides abysmal runtime. In reality something with more than 550 optimistic Mah would be a wiser route. Your flashlight would burn for longer than a birthday candle.
    I want to believe reputable brands that recommend CR123/RCR's as an option are doing so with some foresight. Still, I'll take a 18650 in replacement any day.
    Here is some testing by HTJ on small cells and 18650's.
    Blake
  5. #85
    Join Date
    May 2009
    Posts
    10,124
    Still waiting for the drop-in. Should be here tomorrow or Wednesday. I put an old SST-50 in there just to carry it. Fully loaded it weighs 14.7 ounces of heat-conductive awesome.
    Head: Cryos Cooling Bezel Copper Z32 (M2 size) w/ SS bezel ring
    Body: Fivemega V3 Copper 1x18650
    Tailcap: Cryos Copper Standoff
    Cell: IMR18650
    Drop-in: vinhnguyen54 XM-L2 U3, dedomed, 5a high, H/M/L no memory
    Blake
  6. #86
    Spyderco Forum Registered User Clip's Avatar
    Join Date
    Mar 2012
    Location
    Forest, VA
    Posts
    1,548
    That's a ridiculous chunk of copper.
    Manix2, Elmax MT13, M4 Manix2, ZDP Caly3, ZDP Caly Jr, SB Caly3.5, M390 Para2, Cruwear MT12, Techno, XHP MT16, South Fork, SB Caly3, Manix2 Ltwt, Salt I, 20CP Para2, Military Left Hand, Perrin PPT, Forum Native5, Squeak, Manix 83mm, 440V Military, Gayle Bradley, Swick3, Lil' Temperance, Cruwear Military, VG10 Jester, Terzuola SlipIt, XHP Native Ltwt, Domino, CPM154/S90V Para2, SB Stretch, D2 Para, Dfly2 Salt, Tasman Salt
    Chris
  7. #87
    Spyderco Forum Registered User einstein2001's Avatar
    Join Date
    Jan 2013
    Location
    Endicott, NY USA, Earth
    Posts
    405
    Very nice Blake.
    Cruwear Military, CTS-204P Para 2, K390 Mule
    Southard, Techno, Sage 2, Gayle Bradley
    Super Blue Caly 3, Caly 3.5, Endura and G10 Ladybug
    ZDP-189 G10 Dragonfly, ZDP-189 Nishijin Dragonfly
    -Brandon
  8. #88
    Spyderco Forum Registered User ginsuwarrior's Avatar
    Join Date
    Jun 2013
    Location
    Virginia Mountains
    Posts
    198
    So last week I bought some 18650's (marked Nuon) from BatteriesPlus (BP) store, got them home to find out their too long!! Won't function in my Fenix PD35. I have something called Trust Fire's running in them now, and they seem to work fine. The BP's are about 3/16inch longer than what I'm currently using.
    I call up the manager (the store is an hour from my house) and tell him this, he says he has seen this happen before, and one option I have is to cut the outer wrapper off and inside their would be a smaller battery. Well I did that, and all it revealed was a pink battery with Samsung printed on it, but there is nothing else to be done to make it smaller.
    I go to the store yesterday, was able to return the one I didn't cut into but not the other, which kind of ticked me off because I followed the managers advice, which turned out to be not correct. Anyways, this info might be helpful to some.
  9. #89
    Spyderco Forum Registered User kbuzbee's Avatar
    Join Date
    Aug 2006
    Location
    Mentor, OH
    Posts
    4,248
    That happens. CPF has a lot of threads about 'does battery X work in light Y?' I used to always check those out, but recently, everything I've bought has fit and I've gotten lazy. That will bite me one day soon, I'm sure.
    Ken
    玉鋼
  10. #90
    Join Date
    Jun 2013
    Location
    Virginia Mountains
    Posts
    198
    Yep, now I know.
    Ken what brand 18650's do you use?
    Quote Originally Posted by kbuzbee View Post
    Ken
  11. #91
    Join Date
    Aug 2006
    Location
    Mentor, OH
    Posts
    4,248
    Mostly AWs but I have a couple of the Fenix ones as well.
    Ken
    That PD35 rocks, BTW. From my upstairs window, I can light up the whole backyard with ease.
    玉鋼
  12. #92
    Join Date
    Jun 2013
    Location
    Virginia Mountains
    Posts
    198
    Yeah I'm enjoying TURBO mode, and the strobe is quite intense.
    Ken
  13. #93
    Join Date
    May 2009
    Posts
    10,124
    How quickly you have succumbed to the bright side. Mwua!
    Blake
  14. #94
    Join Date
    Aug 2006
    Location
    Mentor, OH
    Posts
    4,248
    Quote Originally Posted by Blerv View Post
    I blame you, Blake (and many thanks, brother!)
    Ken
    玉鋼
  15. #95
    Join Date
    May 2009
    Posts
    10,124
    I ended up selling my brass Macs SST-50 EDC. The heavy three-mode light was great but I have one very similar in copper that rides in my winter coat.
    This is a Peak Eiger Ultra High CRI, keychain body with a Dark Sucks titanium clip:
    I also grabbed a Oveready Eiger Mule head with a Nichia 219 High CRI LED. No reflector so it's all flood with no reflector, similar to a Zebralight H501 or H502.
    Blake
  16. #96
    Join Date
    Jan 2013
    Location
    Posts
    405
    I just reflowed a Nichia 219 onto my Maratac Cu AAA.
    The color rendition of these emitters are amazing.
    I just love this little copper light, running off a 10440 and now high CRI.
    -Brandon
  17. #97
    Join Date
    May 2009
    Posts
    10,124
    Quote Originally Posted by einstein2001 View Post
    Nice mod!! You fixed the only thing lacking with that tiny light.
    Blake
  18. #98
    Join Date
    Sep 2009
    Location
    Posts
    6,540
    Blerv, nice tritium. I have a few just like it. Justin (I'm pretty sure that's his name, iknitsteel) does very nice work.
    -Brian
  19. #99
    Join Date
    May 2009
    Posts
    10,124
    Thanks Donut It's quite bright but a little bulky.
    I was looking at these. Really cool idea and I like that you can easily change out the vial. Just not sure I wanna spend another $40 on something that glows.
    Blake
  20. #100
    Join Date
    Aug 2006
    Location
    Mentor, OH
    Posts
    4,248
    Nice. Any idea what the output is now?
    Ken
    玉鋼
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
