Page 2 of 8 FirstFirst 1234 ... LastLast
Results 21 to 40 of 142
Thread: Blervís Semi-Comprehensive Flashlight Guide (VERY Long)
  1. #21
    Spyderco Forum Registered User Auxiliaryjohn's Avatar
    Join Date
    Jan 2012
    Location
    SE LA. Dothan, AL
    Posts
    32
    Thanks Blerv. As I get older I have an affection for more than guns and knives. I ordered a JETBeam 3M/III M XML CREE XM-L T6 450-Lumen LED Flashlight just last night to go along with some of my Fenix lights. I just like nice gear. Great writeup and I enjoyed reading it.
    John
  2. #22
    Spyderco Forum Registered User Blerv's Avatar
    Join Date
    May 2009
    Posts
    10,189
    Thanks for reading and kudos on the new acquisition .
    Blake
  3. #23
    Spyderco Forum Registered User bh49's Avatar
    Join Date
    Feb 2006
    Location
    former Constitution state
    Posts
    8,456
    Blake,
    Thank you for sharing. Great flashlight guide for knife people.
    I do not have much knowledge in this area. Just a user. I carry old Novatac 120T., which I bought due to small size and country of origin. With lowest setting of .3 lumens I can navigate inside the house and 120 is sufficient for outside. My wife and I have surefire 60P LED in cars. They are only 80 lumens, but pretty bright for outside for me, much brighter than Novatac @ 120. And just yesterday I got a new toy: Maglite XL200, first light to replace flashlights, which I gave away during last outage. Also US made, only $35 shipped, working on 3 AAA, giving max output of 172 lumen and have very cool way to increase or decrease brightness. It is not a bulletproof like surefire, still nice aluminum anodized body and fraction of cost. It has five settings, which I probably will never use, except the first, which is due to possible adjustments will work fine inside and outside. Probably I will buy one more.
    Please, continue updating and adding to your guide.
    George Orwell
    Any knife without Spyderhole is defective.
    My top choices Native5, G10/VG10 Caly 3.5/3 & C83 Persian Black micarta/bolsters
  4. #24
    Spyderco Forum Registered User defenestrate's Avatar
    Join Date
    Sep 2004
    Location
    on my way to the mountain
    Posts
    2,117
    Thanks, Blerv! Will have to consider this when I am ready to purchase a nice flashlight.
    I don't get mad. I get..Stabby.
    -Fat Tony
  5. #25
    Spyderco Forum Registered User skatenut's Avatar
    Join Date
    Apr 2009
    Location
    Germany
    Posts
    666
    Well done, Blerv! Thank you for a comprehensive write-up.
  6. #26
    Join Date
    Jan 2013
    Location
    Dartmoor,Devon,UK
    Posts
    12
    Hi Blake wow that was very comprehensive I like the custom light, very flashy (sorry) and what you say about the self defence aspects of carrying a powerful torch are so true. If someone tries to attack you at night shine into eyes if they run at you side step smash to the temple with bevel. If they have a knife I would recommend shine into eyes then the Bruce Lee lunging sidekick to the knee its your longest weapon you can also lean back keeping you torso out of reach from
    the knife if all goes well the attacker ends up on the floor now you can get away, if they have gun.... give em everything and grovel....
    And as you state 1 lumen is enough light to see your way around a lot of the time with my Jetbeam thats 80 hours of light on 1 double A battery.
    I carry Jetbeam raptor RRT 0 I liked the fact that it has options to use ether double A or lithium and a control ring for the brightness settings and on my key ring the Fenix E05 simple one light setting, diffuser one triple A battery. Had both for almost 2 years... faultless.
    A JOB WELL DONE I RECKON....
  7. #27
    Join Date
    May 2009
    Posts
    10,189
    Adding basic forumulas and information due to research. Will link to main post body:
    1. Watt hours (Wh)= amps * voltage * hours
    2. 1 Amp = 1,000 Mah.
    3. Approximate runtime minutes:
    * LED forward voltage x current = watts (eg: XML2 3.4v x 800 mah (or .8a) = 2.72 led watts
    * 2.72 divided by driver efficiency (say .9) = 2.72/.9 = 3.02 driver required watts
    * Battery options
    A. RCR123 x 2 = 7.4v (3.7 minimum x 2). 7.4v x 550mah = 4070 (or 4wh)
    B. 18650 x 1 = 3.7v. 3.7v x 3000 mah = 11,100 (or 11.1wh)
    Calculations: 4wh divided by 3.02 driver required watts = 1.32 x 60 minutes = 79 minutes or... 11.1wh divided by 3.02 driver required wats = 3.67 x 60 minutes = 220 minutes
    4. My light says it can handle .8v to 4.2v...: That means it can handle anything from a single Alkaline (1.2v) to a fully charged RCR123 (4.2v) at different brightness levels, if you could fit two RCR123's (8.4v full) it would likely destroy your LED.
    5. My light says it can handle 3v to 13v...: That means assuming it's a less demanding setup (like 1.5v from an XP-G) you could run a single CR123 poorly, a single RCR123 decently, or even 3x 18650's without destroying your LED. This assumes a battery tube that will take any combination . If you tried to use one or two Alkaline batteries at about 2.4v total the driver would not light up the LED.
    6. How is the life of a rechargeable battery taken?: Batteries with an operating voltage of 3.6-4.2 such as Li-Mn or Li-Co batteries are as follows.
    4.2v = Full 100%
    4.1v = about 90%
    4.0v = about 80%
    3.9v = about 60%
    3.8v = about 40%
    3.7v = about 20%
    3.6v = empty
    < 3.5v = overdischarged
    < 3.0v Cell damage based on duration and how low
    Battery Current Estimations (credit to LilKevin715 at Candlepowerforums.com):
    The general rule of li-ion maximum continuous current drain (amps) is 2c of the battery. This means, twice the capacity in an hour. A RCR123 at 750mah would be able to supply 1.5 amps per hour (or 1500mah).
    When running batteries in a series for many applications (direct drive, boost driver, linear regulated) their voltage is added but ability to discharge current remains the same.
    In the example of a "Buck-Driver" or "Step-Down Driver" you can run a multitude of matched similar cells and the current is split accordingly. For example...
    Based on the principle of Power/watts = Volts x Amps
    * A XM-L2 at 3 amps has a forward voltage of about 3.3v to fire up. This means it requires about 9.9 watts of power (amps x voltage = power/watts).
    * A Buck Circuit is 80-90% efficient. Let's assume 80% for sake of example.
    * If the XM-L2 will need 9.9 watts of power then the Buck Circuit will actually pull more due to this inefficiency (9.9 / .8 = 12.375).
    * A CR123 at 1c is 1,500 mah per hour. Under load they drop from about 3.2v to about 2.5v.
    Back to the principle: Power (12.375) spread by using 2x CR123's at a sagging 2.5v each (5v total) would be 2.475 amps per cell, way too high.
    Dividing the 12.375 watts by 7.5v (or 3x CR123) we find the amperage required would be would be 1.63a which is much more safe assuming the cells are matched and quality units.
    Additional Driver Info: Pros vs Cons
    Direct Drive
    Pros: Simple, reliable, efficient
    Cons: Output dims over time, lacks flexibility
    Linear Regulated
    Pros: Able to set "high" mode to current of choice via AMC7135 resistors, etc.
    Cons: Controls lows via PWM, Requires voltage similar to LED (eg: 2.9-4v great, 6v inefficient)
    Step-up/Boost
    Pros: Very flexible with voltage up to 4.2v, regulates well on lower voltage setups, goes direct-drive usually past about 3.6v for high voltage single cells
    Cons: Very inflexible for multiple cell use unless low voltage (ie 3x1.2v alkalines, etc). Only regulates when under forward voltage of LED.
    Step-down/Buck
    Pros: Able to run many cells. Spreads current load by adding cell voltage. Can run high-power LED's with simple low-volt batteries. More efficient than Boost drivers.
    Cons: Requires multi-cell matching, low-voltage will not work, with wide voltage range drivers sometimes won't light up full brightness till about 4.5v (eg 3v-18v driver) still somewhat inefficient.
    Buck-Boost
    Pros: Should be the best regulated out of the bunch
    Cons: Not too common, especially for builders as far as I know.
    Blake
  8. #28
    Spyderco Forum Registered User d.2.the.p's Avatar
    Join Date
    Sep 2011
    Location
    Washington DC
    Posts
    199
    Excellent information, sir. I've always greatly appreciated your input over on EDCF, so I'm glad to see that you've transferred your knowledge over here. Your input is one of the main reasons that I am now a certified Peak addict.
    David
  9. #29
    Join Date
    May 2009
    Posts
    10,189
    Thank you and you are very welcome David! Hope to see you more around here as well .
    Ps: sorry about the addiction! Haha. My brother just got a Peak Eiger Ultra X in brass. Now I want one
    Blake
  10. #30
    Join Date
    Sep 2011
    Location
    Washington DC
    Posts
    199
    Quote Originally Posted by Blerv View Post
    My next acquisition will definitely be something in brass. I have Eigers in both Al and SS and an El Cap in SS, so I need to mix it up a bit.
  11. #31
    Join Date
    May 2009
    Posts
    10,189
    Quote Originally Posted by d.2.the.p View Post
    Very cool I'm eyeballing the Rainier XM-L at RMSK. Direct drive and 700 lumens off a single RCR123 with QTC .
    Blake
  12. #32
    Spyderco Forum Registered User kbuzbee's Avatar
    Join Date
    Aug 2006
    Location
    Mentor, OH
    Posts
    4,284
    Fenix PD 32 inbound. Should be here Mon. Really looking forward to this. Nice update from my PD 30, which I love.
    Ken
    玉鋼
  13. #33
    Join Date
    May 2009
    Posts
    10,189
    Nice Ken! Looking forward to your thoughts
    Blake
  14. #34
    Join Date
    Aug 2006
    Location
    Mentor, OH
    Posts
    4,284
    My thoughts? I LOVE this thing! I can't imagine wanting or needing anything better. Great throw, great flood and plenty of modes from battery miser to ultra bright.
    Terrific in every way.
    Ken
    玉鋼
  15. #35
    Join Date
    May 2009
    Posts
    10,189
    Quote Originally Posted by kbuzbee View Post
    Ken
    Cheers bud. Another obsession is just around the corner!
    Blake
  16. #36
    Join Date
    May 2009
    Posts
    10,189
    I have to upload a picture but my brother just daisy-chained his little AAA Peak light to a Spyderco Spin making for a true "EDC".
    The key is the tip down carry of some of these knives. Anytime the lanyard hole faces downward you can put a small swivel and split-ring through it and into your light. The SS knives like the Cricket, Spin, Balance, etc are ideal in length. I'm sure the Equilibrium will replace it once released .
    Just a little tip to use those LBK's more. Knife + ring + light = awesome.
    Blake
  17. #37
    Spyderco Forum Registered User SpyderNut's Avatar
    Join Date
    Sep 2004
    Location
    Hoosier Country, USA
    Posts
    3,037
    Incredible thread, Blerv. Thanks for putting this together! Your articles were very informative and helpful. I just ordered a Fenix E05 R2 for my EDC purposes. I'll let you know how it works out for me.
    Thanks again!
    Michael
    Live as if you were to die tomorrow. Learn as if you were to live forever.
    Mahatma Gandhi
  18. #38
    Join Date
    May 2009
    Posts
    10,189
    Very cool . Please do!
    Blake
  19. #39
    Spyderco Forum Registered User chuck_roxas45's Avatar
    Join Date
    Mar 2010
    Location
    Small City, Philippines
    Posts
    8,042
    I have more gear than keys on my keyring but what can I do, I'm a gearhead.
    Trust those who seek the truth, but doubt those who say they've found it.
    http://sharpthings.net/chat
    http://www.spyderco.com/forums/showthread.php?t=45696
  20. #40
    Spyderco Forum Registered User Echo63's Avatar
    Join Date
    Oct 2004
    Location
    Perth Australia
    Posts
    554
    Great read - but for anyone reading it - i have a few bits of advice.
    1. buy a decent light, use it, and dont think about it again.
    2. dont go to candlepowerforums.com
    3. if you do go to candlepowerforums, buy the stuff you are going to get anyway - a Malkoff, a good keyring light, and a big hid light (like a Maxabeam)
    then cut your credit card up
    power is nothing without control
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
