Originally Posted by
eyewall
I've been lurking (learning) for a while and joined because I have a question I couldn't find addressed in another thread, so my first post is about a problem. I recently bought a Chaparral and the lock is so tight I can't close the blade without a certain amount of pain and a disfigured thumb. The thin lock bar digs into my thumb and leaves what is becoming a combination of blister/callus and indentations. My wife tried closing the blade and couldn't do it using any method at all. I'm sure the lock is tighter than it should be but I don't see any way to make it better. The mechanism is pretty simple.
My favorite knife at the moment is a Spyderco Dragonfly 2 FRN which I find easy to open and close with one hand.
My thumb is getting shredded by the sharp edges and stiff mechanism on the Chaparral. I don't mind using two hands to close the knife but even that is difficult and painful.
I think it's best that I return it for a refund but I'm curious, if I buy another one should I expect something similar? Is the lock on the Chaparral really this difficult? I feel like there isn't enough room to get the bar down far enough to fully disengage the lock. I can't get it to fully release the blade, the best it will do is let me force it past a strong detent where the lock pops out of the notch.
I'm kind of disenchanted with the Chaparral at the moment. I should add that I did find a thread here in which the internal mechanism was exposed. I disassembled mine to the same state, cleaned everything, oiled it, put it back together and managed to make the blade a little smoother opening but it had no effect at all on the lock.
Any suggestions?
I don't think you have a problem at all. Since you have already voided the warranty, take the CF scales off the side of the knife. What you want to do is gain access to the screw that holds the pin that the lock bar pivots on. You can't see it when the scales are on the knife. With the scales removed adjust the tension on the screw so the lock bar moves easily just using your thumb normally. Then put the knife back together and adjust the blade pivot how you like it. That should take care of it as long as there are no bent parts (liner, lock bar, etc.). You might want to use loc-tite on the screw threads. THREADS ONLY! Make sure none gets between the liners and lock bar or anywhere other than inside the pin the screw screws into. I believe this will work. If it doesn't and I couldn't return it to where you bought it then I'd send it to Spyderco so they can fix it. It may cost you but IMO I like the knife enough to get it fixed. If you hadn't disassembled it already you could send it to them for free but still, I think you can fix it yourself (which is always nice IMO). Be sure to put a drop of good oil on your knife while it is un-put-together. I like to do it then because it's easier to see that all areas are getting lubed. I take the opportunity to apply Tuf-Glide for corrosion control and Nano-Oil on pivot points.
Good luck,
Jack
PS edit: Several people including myself had problems with the pivot on the Chaparral being gritty when opening it. You could even hear it sometimes. The grittyness on mine went away after about a month of fiddling with it even when not using it. You know, opening it when watching tv and such. I think your Chaparral will get easier also even if it doesn't feel perfect after you try to adjust your lock bar screw.
MY CURRENT EDC
Sage4: Now with black linen (micarta) scales, stonewashed blade and bolsters
Manbug (G-10): Now has camo-desert kirinite scales, ZDP-189 blade ground to a Jester-like spine, stonewashed blade and bolsters
Fenix LD01 (single AAA flashlight) clips to Manbug FOB
