Results 1 to 16 of 16
Thread: Parra 2 blade play
  1. #1
    sean rorie is offline Spyderco Forum Registered User
    Join Date
    May 2011
    Location
    Sydney Australia
    Posts
    9
    Parra 2 blade play
    Can some one help.
    I have three parra 2 and all have blade play not up and down but side to side.They were all bought new and had it in the beginning so I have pulled them apart and cleaned and reoiled them but its still there.I was thinking of sanding the pivot ends slightly on very fine wet and dry.Pivots in the knives are tight.Please dont chew me out,I cannot send them back for warranty as I am in Sydney and customs would keep them and destroy.
  2. #2
    Zenith's Avatar
    Zenith is offline Spyderco Forum Registered User
    Join Date
    Mar 2007
    Location
    ZA/RSA: Pretoria
    Posts
    902
    Seems to be part of the new bushing system. Mine has it as well. I just live with it as it does nothing to affect safety or functionality.
    Might try using the search feature for more help.
  3. #3
    Holland's Avatar
    Holland is offline Spyderco Forum Registered User
    Join Date
    Jan 2012
    Location
    Calgary, Alberta
    Posts
    1,381
    teflon tape has worked for me every time. haven't tried locktight yet, but im sure it will have the same effect
    Current Favourites: Sage2, DragonFly2, Paramilitary2, Paramilitary SE, Caly3
    Holland's Knife Hoard
    Extreme Makeover: Paramilitary D2 Edition
    Extreme Makeover: Paramilitary CTS-20CP Edition
    KardinalSyn is offline Spyderco Forum Registered User
    Join Date
    Nov 2011
    Location
    Colombo, Sri Lanka
    Posts
    1,376
    I have only two and both Paras are trouble free. Seems odd to have this happen and feel sad for you.
    Would it be possible to see if you can get similar bushers which are slightly wider? Ask Spyderco first and if no, try locally. You could try this first if possible.
    Centofante3 (C66PBK3), ParaMilitary2 (C81GPCMO), Endura4 (C10P), GrassHopper (C138P), Military (C36GPCMO), Perrin PPT (C135GP), Squeak (C154PBK), Dragonfly 2 Salt (C28PYL2), Military M390 CF (C36CFM390P), R (C67GF), ParaMilitary2 CTS-XHP (C81GPOR2), Tuff (C151GTIP), Ladybug & Perrin Street Bowie (FB04PBB)being the newest.
  5. #5
    Blerv's Avatar
    Blerv is online now Spyderco Forum Registered User
    Join Date
    May 2009
    Posts
    8,329
    IMHO a little play is understandable for any folder. If in factory spec it rarely (if ever) has anything to do with safety.
    While frustrating I can understand your hunt to eliminate it. Just make sure things are buttoned up properly and the mods don't endanger your fingers.
    Cheers,
    Blake
    Listing of Blade-Length Laws by State/County (Not My Website)
    http://www.handgunlaw.us/documents/USKnife.pdf
    Blerv's Semi-Comprehensive Flashlight Guide
  6. #6
    FLYBYU44's Avatar
    FLYBYU44 is offline Spyderco Forum Registered User
    Join Date
    Apr 2008
    Location
    in the wilds of Saskatoon, Saskatchewan, Canada
    Posts
    1,036
    Due to the new pivot design of the Manix 2 and ParaMillie2 there may be some side to side play. I've had several Manix's now and all had side to side play. They use much the same system as a Sebenza, however Spyderco's tolerances are not as tight, so some play will happen. They are not $300-$400 knives, so I would just live with it. Fine sandpaper will likely work, but if you take off too much you can't go back.
    Those who choose to live a life without risks, arrive safely at death's door.
  7. #7
    Join Date
    Apr 2012
    Posts
    40
    I just got one on Monday. No blade play and made in April. Sorry about that though
  8. #8
    Ferris Wheels is offline Spyderco Forum Registered User
    Join Date
    Apr 2012
    Location
    Denver, CO
    Posts
    413
    I hope you are able to get them adjusted to your satisfaction. Good luck with your mods.
    Current : Para2's Brown, Blue & Orange, Etched Spin, CF Caly3 ZDP189, Gayle Bradley, UKPK Orange G10, Manix2 M4, Sage 1, Caly 3.5 in Super Blue, Urban Orange G10
  9. #9
    Join Date
    May 2011
    Location
    Sydney Australia
    Posts
    9
    Blade Play
    Quote Originally Posted by Ferris Wheels View Post
    Thanks guys I can live with it and have been for about a year.They are a great knife.I think I will sell my brand new black bladed camo model I suppose twos enough.I am jealous when I see that Bento Box blue parra.
  10. #10
    gull wing's Avatar
    gull wing is online now Spyderco Forum Registered User
    Join Date
    Sep 2004
    Location
    Louisiana USA
    Posts
    2,542
    Wow! "just live with it". I would not want to.
    With the one you opened up, you could get a machine shop to use the lathe to remove a tiny bit of the sholder area on the pin.(in other words reduce the length of the larger diameter area) This should make the blade tighter. All in all if they should remove too much, you solve the too tight issue by loostening the pivot screw.
    You choose.
    Good luck.
    This has been done by Forum members.
    Waiting for....Calypso Jr.,
    SCARAMOUCHE!
  11. #11
    Blerv's Avatar
    Join Date
    May 2009
    Posts
    8,329
    Quote Originally Posted by gull wing View Post
    You choose.
    Good luck.
    I certainly agree. If it bothers someone there is always something that can be done. It's just a matter of having the right tools/training or money to find someone to perform the mods for you.
    That said, it's important to always clarify mods as such. The OP sounds completely civil and grounded which is refreshing in the world of knife forums . Still, if a modded knife has a lock failure or develops additional quirks I want to be on record with the basic "at your own risk" disclaimer.
    Blake
  12. #12
    Zenith's Avatar
    Join Date
    Mar 2007
    Location
    ZA/RSA: Pretoria
    Posts
    902
    Quote Originally Posted by Blerv View Post
    I agree if it bothers him try and get it sorted. My opinion is "I just live with it as it does nothing to affect safety or functionality".
  13. #13
    Blerv's Avatar
    Join Date
    May 2009
    Posts
    8,329
    Quote Originally Posted by Zenith View Post
    Same here personally. I'm a pragmatist when it comes to folders.
    Blake
  14. #14
    TotinCh1p's Avatar
    TotinCh1p is offline Spyderco Forum Registered User
    Join Date
    May 2012
    Location
    Colorado
    Posts
    10
    I have three PM2s (digi, black, and blue) and the only one without "minimal" side to side play is the blue (and I'd guess since it's the newest). I understand people's expectations with regards to tolerances nowadays, however, it really doesn't bother me. I love being able to open and close the knife with one hand. Also, all of my steel handle spydies (Police, Endure, Harpy) all have the same amount of play.
  15. #15
    Evil D's Avatar
    Evil D is offline Spyderco Forum Registered User
    Join Date
    Jun 2010
    Location
    Northern KY
    Posts
    6,252
    I've owned 3 and all came out of the box rock solid but developed side to side play once broken in. I think the average person wouldn't even know it's there unless you know to look for it. It has absolutely no effect on use. As long as the blade doesn't jiggle when i shake the knife in one hand, i'm good.
    SHARPEN IT LIKE YOU LOVE IT, USE IT LIKE YOU HATE IT.
    Join Date
    Apr 2012
    Location
    Denver, CO
    Posts
    413
    Quote Originally Posted by Evil D View Post
    I am sure once my para2's get more use under their blades they will develop the same play and I am of the same opinion as you Evil.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
