Results 1 to 14 of 14
Thread: Problems with the delica 4
  1. #1
    Fr12nk's Avatar
    Fr12nk is offline Spyderco Forum Registered User
    Join Date
    Feb 2011
    Posts
    4
    i just got my delica yesterday, so i wanted to test the sharpness of it, got a piece of paper and did a cut test. It didnt cut until the very end near the tip, basically its not sharp, so i started to sharpen it on the sharpmaker. But about half way down the blade it wont sharpen for me. I got the top half razor sharp, but the lower end wont get sharp, i can run my finger across and it wont cut, what is wrong, Im kinda upset cause i heard so many good things about this knife. Is it cause its vg10? do i need to push down harder? Please help!!!
  2. #2
    mattman is offline Spyderco Forum Registered User
    Join Date
    Sep 2010
    Location
    Central NY
    Posts
    402
    look up the "sharpie trick". it sounds like the factory bevel is not exactly 30°, and you aren't getting all the way to the edge yet.
    remember, these are hand-sharpened at the factory.
    the operation you are performing is "reprofiling", and sharpening will be much easier next time.
  3. #3
    Blerv's Avatar
    Blerv is offline Spyderco Forum Registered User
    Join Date
    May 2009
    Posts
    8,341
    Mark both sides with a permanent marker and do a few strokes to make sure it's sharpening properly. Sometimes the secondary bevel isn't perfect as the knives are sharpened on a power belt.
    You should be able to get it sharp pretty easy. VG10 is user friendly in such a thin edge. Goodluck!
    Edit: wow it's like Matt read my mind or visa versa.
    Blake
    Listing of Blade-Length Laws by State/County (Not My Website)
    http://www.handgunlaw.us/documents/USKnife.pdf
    Blerv's Semi-Comprehensive Flashlight Guide
  4. #4
    araneae's Avatar
    araneae is offline Spyderco Forum Registered User
    Join Date
    Aug 2006
    Location
    South of the Erie shore, Ohio
    Posts
    3,447
    More than likely operator error on the Sharpmaker. Being new here, we don't know what your experience level is. Try the Sharpie trick and see what's going on. What was your process on the Sharpmaker- angle? stones?
    Nothing wrong with VG-10, you don't need to push hard at all. Just medium pressure will produce very good results.
    Quote Originally Posted by mattman View Post
    So many knives, so few pockets...
    -Nick
    Light Modding and Wharnifying when time permits
    Just got:Super Leaf
  5. #5
    maa14's Avatar
    maa14 is offline Spyderco Forum Registered User
    Join Date
    Nov 2011
    Location
    TEXAS
    Posts
    359
    Quote Originally Posted by Blerv View Post
    +1 and VG-10 Is some GREAT stuff. Once you get it sharp I am sure you will like it
    's =FFG ZDP-189 Delica...Manix2...saber grind VG10 Delica...bug...Blue M390 Paramilitary 2...SE hawkbill Ladybug salt...sharpmaker with UF stones.orange and red baliyo...
    Latest purchase=Gayle Bradley
  6. #6
    angusW's Avatar
    angusW is offline Spyderco Forum Registered User
    Join Date
    Mar 2009
    Location
    Hamilton, Ontario
    Posts
    1,460
    Are you using the 30° or 40° on the Sharpmaker? Also do you have a loupe or some kind of magnifying glass as that will really help you to see what kind of progress you are making. When I first got the Sharpmaker I was in the same boat and with reading on this forum and Bladeforum I realized my mistakes and was able to correct it. Do lose faith. Once you get your technique down you will be able to sharpen that Delica and make it very sharp.
    Member of the LH Military club.
    My Spydies
  7. #7
    maa14's Avatar
    Join Date
    Nov 2011
    Location
    TEXAS
    Posts
    359
    Quote Originally Posted by angusW View Post
    you mean, don't, right??
  8. #8
    angusW's Avatar
    Join Date
    Mar 2009
    Location
    Hamilton, Ontario
    Posts
    1,460
    Quote Originally Posted by maa14 View Post
    Stop it. I'm trying to make him lose all hope and feel despair
    My Spydies
  9. #9
    maa14's Avatar
    Join Date
    Nov 2011
    Location
    TEXAS
    Posts
    359
    Hehe..whatever
  10. #10
    dbcad's Avatar
    dbcad is offline Spyderco Forum Registered User
    Join Date
    Jan 2010
    Location
    ga, usa
    Posts
    2,624
    I have to add this advice to the OP in addition to some of the good tips above
    Do not try to sharpen if you're frustrated!! It's a recipe for failure. Be calm, know what you're trying to do, have the right tools to know where you are and where you need to go. Take this from a very untalented edge nut that now has very sharp edges
    Charlie
  11. #11
    Fr12nk's Avatar
    Join Date
    Feb 2011
    Posts
    4
    Thanks you guys, i somewhat got it sharp, i did the sharpie trick and saw that it wasnt touching when i ran the knife straight up and down, on 30 degrees, so i tilted the knife so it would be at a sharper angle. Then it started to sharpen, but still i cant get the bottom portion of the blade razor sharp.
  12. #12
    Join Date
    Oct 2011
    Location
    Plano, Texas
    Posts
    281
    I had a lot of trouble getting a decent bevel on a Delica 4 as well. I finally gave up and practice on the sharpmaker with "easier" steels. Sharpen some of your cheaper knives for a while. After I mastered that, I went back to my Delica 4 and got it shaving sharp. I was so pleased!
  13. #13
    eloreno's Avatar
    eloreno is offline Spyderco Forum Registered User
    Join Date
    Sep 2010
    Location
    In the Adirondacks
    Posts
    221
    Quote Originally Posted by Fr12nk View Post
    If you were to use the 40° setting, I bet you would have better results....
  14. #14
    araneae's Avatar
    Join Date
    Aug 2006
    Location
    Posts
    3,447
    I think you need to watch the video again. Go through the process as it shows and you should have good results.
    -Nick
    Just got:Super Leaf
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
