Results 1 to 10 of 10
Thread: need some help please
  1. #1
    dskmanch is offline Spyderco Forum Registered User
    Join Date
    Sep 2004
    Location
    Manchester United Kingdom
    Posts
    80
    Exclamation need some help please
    hi all
    i'd like to take some pictures of my collection, but am really struggling to get decent results. i have a dSLR, but think my lack of success is because i don't have a lightbox - the lighting from the flash alone gives horrible results.
    now i'd appreciate suggestions on how to make my own, or some pictures of the lighting setup others are using to get their results.
    thanks very much
    May I deal with honour
    May I act with courage
    May I achieve humility
  2. #2
    Join Date
    Aug 2009
    Location
    Belgium
    Posts
    136
    Quote Originally Posted by dskmanch View Post
    hi all
    thanks very much
    i'd say put off the flash. I don't have any profesional equipment. I have an cheap nikon camera with macra and a daylight lamp.
    Gives me results i'm proud of
    Or i go outside
    Pim
  3. #3
    Join Date
    Sep 2004
    Location
    Upstate SC, USA
    Posts
    19,803
    This is the lightbox I use, and I highly recommend it.
    http://www.thinkgeek.com/electronics...tography/a205/
    The other "must have", in my opinion, is a tripod. It does not need to be top of the line, WalMart sells decent ones for around $30.
    My Personal Website ---- Beginners Guide to Spyderco Collecting ---- Kiwimania ---- Spydiewiki
    Dead horses beaten, sacred cows tipped, chimeras hunted when time permits.
  4. #4
    LorenzoL's Avatar
    LorenzoL is offline Spyderco Forum Registered User
    Join Date
    Mar 2009
    Posts
    809
    OK, here is how I do it:
    DSLR set to aperture priority, with an aperture of 11 of less to have a good depth of field. A macro lens is not required unless you want to capture details, I prefer a 35 to 50 mm equivalent.
    Shoot RAW so that you have more latitude in PP.
    A tripod is absolutely necessary.
    I shoot with natural light that I bounce off a reflector, so no flash. Properly placing the reflector is achieved by trial and error. The tricky part is to retain detail on the highlight areas like the blade.
    Finally, I place a neutral gray card in one corner of the frame, where it does not affect the composition and can be cropped later. You will use that card as the reference to adjust the white balance during post production.
  5. #5
    rangefinder is offline Spyderco Forum Registered User
    Join Date
    Apr 2009
    Posts
    21
    There are lots of knife photography tips in this thread on Blade Forums: http://www.bladeforums.com/forums/sh...d.php?t=328550
    Ken Lunde has info on his process at the bottom of this page: http://lundestudio.com/firearms.html
  6. #6
    LorenzoL's Avatar
    Join Date
    Mar 2009
    Posts
    809
    I forgot to add that when using a tripod any image stabilization system you may have on the camera or the lens should be turned off.
  7. #7
    Join Date
    Sep 2004
    Location
    Posts
    80
    thank you all very much - your help and advice is very much appreciated.
    i have some reading to do and then some experimenting and soon i hope to have some pictures that will do justice to the knives i have
    i'll then post them up for your opinions
  8. #8
    merthyrmafia's Avatar
    merthyrmafia is offline Spyderco Forum Registered User
    Join Date
    Jul 2008
    Location
    I live in Merthyr Tydfil South Wales.
    Posts
    167
    Taking good shots with my digital SLR.
    One make sure all your white balance settings are correct, such as if you are shooting indoors under tungsten light, or floresent, set your white balance ,
    tips, colour set to vivid, make sure you use a tripod very important for composing your photo, means you have more control, make sure your shutter speed and appertures balance, with a tripod you can use slow shutter speeds with the knowledge you wont blur the shots, dont be affraid to focus up closely to the subject, try with flash and without flash, and have a look at some pictures of knives which you think are good and copy what you see, also natural light as long as it's not to harsh always looks good, if it's to strong use a fine diffuser, and dont be a scared of playing around with the settings, because you are using a digital SLR there's no waste if you dont like it when you upload it to your computer delete it, but also with he editing system most computers have these days you can slightly tweak your shots, such as sharpening, colour enhancement contrast so on.
  9. #9
    ozspyder's Avatar
    ozspyder is offline Spyderco Forum Registered User
    Join Date
    Dec 2006
    Location
    Sydney, Australia
    Posts
    2,973
    I have good results from generally using no tripod, no lightbox and no flash.
    For idiot-proof results try shooting in overcast conditions or with any filtered light (ie: indoors with light from a window or bounced light)
    A tripod is good and you should use one. I am lazy and cannot be bothered grabbing a tripod on most occasions
    Aperture settings as per above is good to follow but it depends on whether you want to capture a lot of detail/ depth of field or if you want to limit it to get certain effects or artistic impressions on certain features of a knife/ knives.
    From my own experience in shooting my own knives and other subject matter.... it is al about composition. Choose a subject or a theme and go for it. Not necessarily required to shoot a whole knife in one frame. Try shooting features, try different backgrounds/ foregrounds, try different lighting and camera settings.
    The beauty about the digital era is that we can now shoot as many shots as you like and experiment with different settings. Delete anything you don't like, keep the ones you do and try to remember the settings you had on those and go experiment some more and refine to find you own 'style'
    Can't wait to see your results !
    Cheers
    I love my: Persians, Kopas, and Lums
    * Daniel's Spyderco Hoard *
  10. #10
    Join Date
    Sep 2004
    Location
    PA, USA
    Posts
    2,109
    Lots of great info here.
    Work EDC List
    FRP: Nisjin Cricket PE, Bug
    FLP: SS Cricket SE, ZDP Dragonfly2 PE
    Tom Krein TK-1 neck knife carried traditionally
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
