Results 1 to 13 of 13
Thread: RIL Military (Knifeworks LE) or Standard Military
  1. #1
    BillyJack's Avatar
    BillyJack is offline Spyderco Forum Registered User
    Join Date
    Nov 2009
    Posts
    8
    Question RIL Military (Knifeworks LE) or Standard Military
    Ok guys. I have the LE RIL Military on pre-order at Knifeworks. I am trying to decide which Milli to go with. I do not mind the LL or the FL. Which one is going to be stronger? I understand the standard LL is very strong on the Milli, and is one of the strongest in the industry. I read Sal was saying it could withstand 500 lbs of force. That's pretty impressive. Does anyone know how much force the RIL version can withstand. Logically I would think the RIL would stronger because of the thickness difference.
    What are some other pros and cons of each? I'm not too concerned about the different steels. I have expierence with both the CPM-M4 and CPM-S30V. IMO they are both good steels.
    Brad
  2. #2
    yablanowitz's Avatar
    yablanowitz is offline Spyderco Forum Registered User
    Join Date
    Apr 2006
    Location
    Liberal, Kansas
    Posts
    3,859
    Just so you will know, the cutout at the base of the lockbar on the TiRIL Military measures 0.048" thick. The liner/lockbar on the regular Military measures 0.048" thick. One is titanium, one is steel. Guess which is likely to be stronger.
    The old 440V Millie with one partial liner was strong enough to stand up to anything someone with two active brain cells is likely to dish out. Any of the others will be as well. Choose by steel and handle preference.
  3. #3
    jzmtl is offline Spyderco Forum Registered User
    Join Date
    Aug 2008
    Location
    Montreal, Canada
    Posts
    1,415
    That sounds awfully thin for a frame lock.
  4. #4
    gunmike1's Avatar
    gunmike1 is offline Spyderco Forum Registered User
    Join Date
    Mar 2006
    Posts
    676
    Quote Originally Posted by jzmtl View Post
    That's the cutout. I've seen lots of "Hard Use" knives with RIL posted by STR to have cutouts as thin as .032" or so. I believe Sal said the RIL Millie was being engineered for the same strength as the liner lock Millie, so maybe the cutout being a similar size in a weaker material would make for a similar strength lock due the the rest of the lock bar being thicker and the possibly having to do with where the cutout is placed rather than just having the cutout thickness limiting strength to what an equivilant thickness liner lock would be. STR, or better yet Spyderco's lock breaking machine could probably answer that question. I do find it humorous though when I see so many people claim the RIL is by far the strongest lock on the market. The Chinnok lock back, Manix 2 Caged Ball Lock, the Superhawk and Para's comp lock, and the Axis lock should crush most any RIL for ultimate strength. The new Bradley M4 folder and it's .072" thick liner lock should beat out most RIL's as well, as that is one beefy hunk of stainless steel locking up that M4 blade.
    Mike
  5. #5
    Join Date
    Aug 2008
    Location
    Montreal, Canada
    Posts
    1,415
    Ah I get it now. Took me a while to connect cutout to where it is.
  6. #6
    demtek9's Avatar
    demtek9 is offline Spyderco Forum Registered User
    Join Date
    Sep 2004
    Location
    Colorado Springs
    Posts
    517
    I don't think the RIL is any stronger. Its just a safe feeling knowing your fingers actually put force towards the locked position when open. Same could be said for lockbacks with the Boyd dent.
    ...oh you know why!
  7. #7
    Join Date
    Sep 2004
    Location
    Upstate SC, USA
    Posts
    19,732
    Granted, the last time I was in a physics classroom was damn near 50 years ago, but it does seem a bar .048 thick for its entire several inches of length would be easier to flex than a bar of equal length several times that thickness for all but a very short section of that length.
    That said, I'd most definitely agree with this...
    Quote Originally Posted by yablanowitz View Post
    My Personal Website ---- Beginners Guide to Spyderco Collecting ---- Kiwimania ---- Spydiewiki
    Dead horses beaten, sacred cows tipped, chimeras hunted when time permits.
  8. #8
    Join Date
    Apr 2006
    Location
    Liberal, Kansas
    Posts
    3,859
    It is easier to flex. That doesn't make it easier to break.
  9. #9
    JNewell's Avatar
    JNewell is offline Spyderco Forum Registered User
    Join Date
    Sep 2004
    Location
    Land of the Bean and the Cod
    Posts
    3,375
    I would think that in ordinary use the strength of the stop in would be of more significance than the strength of the lock bar. Am I missing something?
  10. #10
    Join Date
    Apr 2006
    Location
    Liberal, Kansas
    Posts
    3,859
    It depends on your definition of "ordinary use". For my ordinary use, the lock is pretty much superfluous. I use slipjoints all the time. For others, ordinary use seems to require a locking mechanism that is stronger than the blade. Why? No real clue, and the only reasons I can think of tend to be...let's just say "uncomplimentary" and leave it at that.
  11. #11
    Joshua J. is offline Spyderco Forum Registered User
    Join Date
    Mar 2006
    Location
    Central Alberta, Canada.
    Posts
    835
    Cutting thick cardboard your blade gets jammed in all the time. While wiggling it out you don't particularly care what angles pressure is being applied, you just want to finish cutting the cardboard.
    This is one of the more common places where you'll see lock failure, I've heard of locks failing on something as simple as chopping twigs though.
  12. #12
    JNewell's Avatar
    Join Date
    Sep 2004
    Location
    Posts
    3,375
    I treat every folder as if it were a slipjoint. I've seen so many things do unintended or unexpected things over the years that I try to make sure that when they happen I won't get cut.
  13. #13
    Join Date
    Apr 2006
    Location
    Liberal, Kansas
    Posts
    3,859
    Quote Originally Posted by Joshua J. View Post
    After you cut yourself enough times, you begin to care.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
